Need fast brake help!!!
Old 07-14-2004, 12:50 PM
Default Need fast brake help!!!
On my other car, when I push the brake pedal down, there is almost no resistance at all and it goes to the floor very easily, but the brakes still work really well.
It has a new master cylinder, new calipers, new pads and new rotors.
There are no leaks anywhere I can see, and it doesn't leave puddles on the ground.
What else could this be??
Briman2021 is offline
Old 07-14-2004, 12:53 PM
EL Vap133's Avatar
Default Re: Need fast brake help!!! (Briman2021)
Did you bleed the brakes?
EL Vap133 is offline
Old 07-14-2004, 12:55 PM
New User
mercury's Avatar
bubbles in the line?
mercury is offline
Old 07-14-2004, 12:57 PM
del_parker's Avatar
Default Re: Need fast brake help!!! (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Did you bleed the brakes? </TD></TR></TABLE>
del_parker is offline
ITR#JohnBasedow's Avatar
Dish the ball early for a successful fast brake.
ITR#JohnBasedow is offline
Old 07-14-2004, 01:22 PM
Default Re: (ITR#jason)
definately have bled the brakes at least 5 times, no bubbles coming out of anywhere, we bench bled the master cylinder too.
Old 07-14-2004, 01:32 PM
NrG
NrG's Avatar
Default Re: (Briman2021)
adjust the rod on the peddle.
NrG is offline
Patrick18
02-26-2015 10:01 AM
dwarrick
05-19-2006 10:45 AM
paawk2000
07-05-2005 04:11 PM
Abshonda
03-23-2004 05:15 PM
MisterB
12-04-2002 04:46 PM
Quick Reply: Need fast brake help!!!
