Katana Sword vs. Browing M2 .50 Cal Machine gun
Old 12-02-2004, 08:53 PM
IloveNewt's Avatar
Default Katana Sword vs. Browning M2 .50 Cal Machine gun
IloveNewt is offline
Old 12-02-2004, 08:55 PM
ciVick_EX's Avatar
Default Re: Katana Sword vs. Browing M2 .50 Cal Machine gun (MordecaiPSI)
Link is insanely slow... can't d/l.
Edit: Ok, nevermind, it's coming now.
ciVick_EX is offline
Old 12-02-2004, 08:56 PM
OG triple OG
ATS*Mark's Avatar
Default Re: Katana Sword vs. Browing M2 .50 Cal Machine gun (ciVick_EX)
aint workin for me.
ATS*Mark is offline
Old 12-02-2004, 09:03 PM
Lastgsr's Avatar
Default Re: Katana Sword vs. Browing M2 .50 Cal Machine gun (Hella_JDM)
whoa... japanese with korean subtitles.
it sliced the bullet in two, thats ninja
Lastgsr is offline
Old 12-02-2004, 09:04 PM
flowbee's Avatar
.50cal > katana
flowbee is offline
Old 12-02-2004, 09:05 PM
IloveNewt's Avatar
Default Re: Katana Sword vs. Browing M2 .50 Cal Machine gun (flowbee)
I wonder if it was using depleted uranium rounds. If so they r crazy hard/dense. The sword held up for 7 rounds....not bad.
Old 12-02-2004, 09:11 PM
ciVick_EX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flowbee &raquo;</TD></TR><TR><TD CLASS="quote">.50cal &gt; katana </TD></TR></TABLE>
Big time... I thought they would shoot a regular gun, not a ******* cannon.
Old 12-02-2004, 09:13 PM
That is VERY impressive.
The Sword stood up to several bullets.
Talk about craftsmanship.
I wonder how they make them? I heard it was folded, but I don't really know the details.
.Chris. is offline
Old 12-02-2004, 09:15 PM
Head Of Bespoke
Rguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MordecaiPSI &raquo;</TD></TR><TR><TD CLASS="quote">I wonder if it was using depleted uranium rounds. If so they r crazy hard/dense. The sword held up for 7 rounds....not bad.</TD></TR></TABLE>
7 rounds in almost the exact same spot.
It could hold probably 40 shots if you didnt actually hit the exact same spot everytime.
Impressive
Rguy is offline
ciVick_EX's Avatar
Default Re: Katana Sword vs. Browing M2 .50 Cal Machine gun (Black204GSR)
Yeah that's correct. They keep hardening the iron several times... I forget the name of the process though.
Old 12-02-2004, 11:51 PM
wall of tvs's Avatar
wall of tvs is offline
Old 12-02-2004, 11:53 PM
OG triple OG
ATS*Mark's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ciVick_EX &raquo;</TD></TR><TR><TD CLASS="quote">Yeah that's correct. They keep hardening the iron several times... I forget the name of the process though.</TD></TR></TABLE>
its called hardination.
ATS*Mark is offline
Old 12-03-2004, 12:23 AM
del_parker's Avatar
that download is uber slow...
http://www.yourencyclopedia.net/Katana.html
del_parker is offline
Old 12-03-2004, 09:20 AM
IloveNewt's Avatar
Default Re: Katana Sword vs. Browing M2 .50 Cal Machine gun (del_parker)
yea it is very slow.
Old 12-03-2004, 09:26 AM
Notorious N.A.G's Avatar
They typical samurai sword (not the ones you buy at disney world or the asian shop) are folded a thousand times over. They use clay as well for the cooling process. Clay helps the cooling slow so the back of the sword is less rigid while the edge of the blade is hard to help keep the edge. These kinds of swords you can't just buy in the mall. They take at least a month to make. I was actually considering getting one. they are 7-10 grand an aprentice or master will make it for you custom. Though I would really love a cherry blossom vitory sword from wwII officers.
Notorious N.A.G is offline
Old 12-03-2004, 09:41 AM
Banned
Default Re: Katana Sword vs. Browing M2 .50 Cal Machine gun (Notorious N.A.G)
DAMN! The bullets were sliced in half!
LSVTEC 91 Civic is offline
Old 12-03-2004, 09:42 AM
sifu pai mei
LaosGuySi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black204GSR &raquo;</TD></TR><TR><TD CLASS="quote">That is VERY impressive.
I wonder how they make them? I heard it was folded, but I don't really know the details.</TD></TR></TABLE>
Material Iron
Japanese sword is made of mainly two different irons, called "Tamahagane" and "Hochotetsu". Tamahagane is the hardest and rare iron, and the second hardest is Hochotetsu, which is generally used for a kitchen knife. .They are extracted from iron sand from mountains with the special equipment called "Tatara" with low heat and long time. After that process, you can have only a small amount of Tamahagane, so Tamahagane is very expensive. Tamahagane is so rare and expensive that it is normally added by "Oroshigane"--- a mixture of some different hardness irons like Hochotetsu --- to make a katana.
Structure of Katana
Japanese katana is made of two different hardness irons, the outside is the hardest iron containing Tamahagane, which is called "Hitetsu", and the inside is called "Shintetsu" used less hard iron. And using two different irons, soft inside and hard outside, makes Japanese swords "hard but unbreakable".
Process for making Katana
Heat the Tamahagane and Oroshigane with very hot fire to forge it. Strike and stretch it with a hammer and fold it into two. It requires high technique because when you fold the iron, you must not put air in between. Continue those works many times to make the iron harder and purer. When you fold the iron ten times, the layers will be 1024. Then, forge the iron for Shintetsu by the same process as the Tamahagane. Attach the Shintetsu and the Hitetsu. And strike it with a hammer to make the shape of Katana. Put "Hamon" on the Katana with a spatula. Heat the Katana with very hot fire. Cool the Katana by putting it into cold water. Sharpen the Katana. This work is called "Togi", and done by the specialist of Togi. It takes one month. At this stage, the katana becomes very sharp. To make 100% real Japanese sword very sharp and strong, it has to go through all this process
LaosGuySi is offline
Old 12-03-2004, 09:57 AM
.DOHChi
Guest
Posts: n/a
Default Re: Katana Sword vs. Browing M2 .50 Cal Machine gun (PistonHondaEM1)
why not jsut have science make u one. using titanium or even cobalt. i bet that is a lot stronger, sharper and lighter. hell, i bet it's even cheaper. wonder if it can be done?
Old 12-03-2004, 11:34 AM
ekhatch18tR's Avatar
Only if they made pistons like that..."Hanzo pistons" i'd be able to boost 30 psi on 87 octane all day
ekhatch18tR is offline
Old 12-03-2004, 11:36 AM
tony4311's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Notorious N.A.G &raquo;</TD></TR><TR><TD CLASS="quote">They typical samurai sword (not the ones you buy at disney world or the asian shop) are folded a thousand times over. They use clay as well for the cooling process. Clay helps the cooling slow so the back of the sword is less rigid while the edge of the blade is hard to help keep the edge. These kinds of swords you can't just buy in the mall. They take at least a month to make. I was actually considering getting one. they are 7-10 grand an aprentice or master will make it for you custom. Though I would really love a cherry blossom vitory sword from wwII officers. </TD></TR></TABLE>
I've always wanted a real sword but could never afford it.
tony4311 is offline
morepoop4u
General Discussion and Debate
10
12-23-2004 02:57 AM
816d16
38
11-17-2004 08:15 AM
Ri5e
21
10-01-2004 07:50 PM
slammed EG
01-15-2004 11:53 PM
Dorikamu
Honda Motorcycles
11-18-2002 01:48 PM
Quick Reply: Katana Sword vs. Browing M2 .50 Cal Machine gun
