Hep remove Honda crank bolt with no hex tool shape - Honda-Tech - Honda Forum Discussion
Go Back  Honda-Tech - Honda Forum Discussion > Community Forums > General Discussion and Debate
Reload this Page >
Old 07-10-2018, 04:54 AM
KILLAB17VTEC
acmoc's Avatar
Default Hep remove Honda crank bolt with no hex tool shape
I need to pull the crank pulley off. How do I stop it from moving. My crank puley does not have the hex shape for the honda tool.
just a bunch of holes, keeps rotating the motor. I took the flywheel cover off but don't see where or how to jam it and can't find any images on how to do this despite many people saying to do this
I did not post this in the tech section because I need a fast answer. I'm sure someone here knows how to
acmoc is offline
Old 07-10-2018, 04:55 AM
something gnarly
5SpdH22's Avatar
Default Re: Hep remove Honda crank bolt with no hex tool shape
wrap chain wrench around pulley with old serp belt in between, then pin it against ground
5SpdH22 is offline
Old 07-10-2018, 04:56 AM
LightningTeg's Avatar
Big pry bar or screwdriver wedged into teeth of flywheel and floor or frame of car.
Chain wrench around crank pulley, although gotta watch you dont marr the **** out of it. (Edit: beat me to it, put a belt in between)
LightningTeg is offline
Old 07-10-2018, 05:02 AM
I am SO fancy!
silvertaxasteg's Avatar
Easiest way. I had a strap wrench and an old belt I cut to fit the circumference of the pulley. Worked like a charm.
silvertaxasteg is offline
Old 07-10-2018, 05:06 AM
KILLAB17VTEC
acmoc's Avatar
I don't see how to wedge the flywheel. Mine is covered by the bell housing, even with the cover off I only can see the side of it,
I'm going to try the chain whip. Where can I buy one? I have an old belt and my car has no AC or PS so It wob't be a problem if it gets marred a little.
Is this it?
https://www.autozone.com/loan-a-tool...ter/695599_0_0
acmoc is offline
Old 07-10-2018, 05:10 AM
something gnarly
5SpdH22's Avatar
Might be called 'locking chain clamp' or 'locking chain pliers'. I think I bought mine at autozone. It's pretty garbage, but I did 4 timing belts with it.
5SpdH22 is offline
Old 07-10-2018, 05:15 AM
KILLAB17VTEC
acmoc's Avatar
acmoc is offline
Old 07-10-2018, 05:16 AM
I am SO fancy!
You want something like this.
Or this, in a pinch.
Old 07-10-2018, 05:17 AM
I am SO fancy!
Originally Posted by acmoc View Post
Double check your pulley's circumference, make sure the chain is long enough.
Old 07-10-2018, 05:18 AM
KILLAB17VTEC
acmoc's Avatar
What's the rubber one called?
acmoc is offline
Old 07-10-2018, 05:25 AM
I am SO fancy!
Old 07-10-2018, 06:12 AM
sde780's Avatar
There should be holes in your crank pulley no? Take a flat piece of rebar, drill two holes that match, insert bolts to bolt it up and make your own crank pulley tool.
sde780 is offline
Old 07-10-2018, 07:35 AM
muellersfan's Avatar
Who needs an expensive compressor anymore?
This cordless impact removes a stubborn crank bolt in about 2 seconds.
muellersfan is offline
Old 07-10-2018, 07:39 AM
tony_2018's Avatar
sayin...going postal costed op so now he has to do everything by hand tools.
tony_2018 is offline
Old 07-10-2018, 07:44 AM
Touching My Member
.Manny.'s Avatar
3d print an impact gun.
.Manny. is online now
Old 07-10-2018, 07:45 AM
something gnarly
5SpdH22's Avatar
5SpdH22 is offline
Old 07-10-2018, 07:53 AM
Keyboard Humorist
4drEF's Avatar
Have wedged a big flathead screwdriver between the flywheel teeth and bellhousing.
I have never cracked anything.
You could also rig something up to hold between one of the inspection plate bolts and a bolt or hole in the flywheel.
4drEF is offline
Old 07-10-2018, 07:58 AM
Moderator
snobordboy's Avatar
This is a good idea, but what are you using to try and break it loose? I have yet to need a pulley tool when using a decent impact to remove a crank pulley bolt on any Honda that I have encountered.
snobordboy is offline
Old 07-10-2018, 08:14 AM
footwork mastery
.Grimace's Avatar
Man I would be helpful and tell you an easy way but my banana dick yellow civic doesn't have this issue. It's an adult car
.Grimace is offline
Old 07-10-2018, 10:13 AM
tony_2018's Avatar
1st gen problems....
Old 07-10-2018, 02:53 PM
Screw you guys, I'm... going... home.
tjbizzo's Avatar
Take spark plug out of #1 cylinder, pour in a cup of BBs, reinstall spark plug. Then when you use your impact on the crank pulley, the #1 piston will hit the fistful of BBs and stop the crank from turning. You could also use a cup of sand, nails, gold chains, etc.
tjbizzo is offline
Old 07-10-2018, 11:30 PM
KILLAB17VTEC
acmoc's Avatar
I just put a extension in the hole and it stopped against the frame nicely
put wd40 on that bish like i do with grimace
used friends harnour freight earthquake impact. Puits nore torque than ricos mom on a lawn chair
Anyway, was sooo easy.
Just make sure the lectric impact is fully charged and you have as short as possible socket.
What's the tq. spec on d16a6 timing belt tensioner? 33 ft lbs?
crank bolt? 1124 ft lbs?
The bolts that tie the engine mount bracket to the head? I don't have a clue on this one.
Anyway, thanks everyone.
acmoc is offline
Old 07-11-2018, 08:30 AM
Steve at Heart
Bently_Coop's Avatar
My Man
@Acmoc according to a recent study by Dazman torque wrenches are useless, to many variables. Besides I thought your arm was calibrated.
Bently_Coop is offline
Old 07-11-2018, 08:31 AM
footwork mastery
.Grimace's Avatar
I like that I have annoyed you enough you go out of your way to mention me.
.Grimace is offline
Old 07-11-2018, 09:48 AM
eight equals equals equals D
Tim2179's Avatar
most crank pulleys don't have a hex cut out - and yet - here we are in 2018.
Tim2179 is offline
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
