2018 Ford Mustang
Old 01-18-2017, 11:01 AM
rookn00b
xtrac1's Avatar
Default 2018 Ford Mustang
Some changes:
V6 model gets the axe.
Both the 4 cylinder EcoBoost and V-8 GT gets a power boost.
GT uses both port and direct injection and a bump in compression ratio, 11.0:1 to 12.0:1.
Ford MagneRide magnetorheological adaptive dampers available in both (4cyl/8cyl) performance packages.
Six-speed manual transmission (which gets a twin-disc clutch and a new dual-mass flywheel on V8 models)
or
10-speed auto co-developed with GM.
xtrac1 is offline
Old 01-18-2017, 11:06 AM
White Trash Wish Cash
rino924's Avatar
Default Re: 2018 Ford Mustang
Not bad. Looks like a Mazda 3 front end
rino924 is offline
Old 01-18-2017, 11:11 AM
talks to himself
CX-Adam's Avatar
This is the image I was waiting for. Everyone is hating on the front end and I couldn't see the difference.
CX-Adam is offline
Old 01-18-2017, 11:14 AM
aka DaZman69!
Direct and port injection? Wow nice
Mag ride + stiffer chassis
Someone wants to stopped getting molested by the camaro, wonder if it will work
sflkgjsfndgn is offline
Hookers and blow
dipsy's Avatar
I don't like the head lights.
dipsy is offline
Old 01-18-2017, 11:17 AM
at the jetties fishin'
stackz's Avatar
wonder if you can swap bellhousings on the 10 speed? hmmm
stackz is offline
Old 01-18-2017, 11:27 AM
aka DaZman69!
I'm most familiar with gm, and when they went to direct injection, literally nothing on the engines and transmissions is compatible with older generations. The new DI engines were built from scratch that happen to have the same discplacement. I'd imagine ford is doing something similar.
Old 01-18-2017, 11:32 AM
stackz's Avatar
no, what I meant is ford/gm designed the tranny together so I'm wondering if the main body of it will fit either make? thats all.
stackz is offline
Old 01-18-2017, 11:35 AM
Head Of Bespoke
Rguy's Avatar
Why cant they tell us the power increases....
Rguy is offline
Old 01-18-2017, 11:53 AM
INSERT TITLE HERE
newt2's Avatar
12:1? Yikes! Low margin of error on 91 octane.
newt2 is offline
Old 01-18-2017, 11:54 AM
Head Of Bespoke
Rguy's Avatar
What say you about mazda skyactiv 14:1 compression?
Rguy is offline
Old 01-18-2017, 11:58 AM
INSERT TITLE HERE
newt2's Avatar
I didn't realize they were pushing that high these days. That's pretty sweet. I'm guessing they have really good control on the timing?
newt2 is offline
Old 01-18-2017, 12:01 PM
I'm curious how much stronger the new 6spd is compared to the current mt-82.
hinds90 is offline
Old 01-18-2017, 12:10 PM
Touching My Member
.Manny.'s Avatar
I like the new headlights more than the old.
.Manny. is offline
Old 01-18-2017, 12:34 PM
aka DaZman69!
yes, well now they essentially have "fuel timing"
you can't really do much with injector pulsing in port injection because it just gets sucked in when the intake valve is open. Being directly injected into the combustion chamber essentially allows you to inject whenever the **** you want. It virtually eliminates detonation, which in turn safely allows higher compression ratios.
one major downside is that you now don't have any fuel constantly spraying and cleaning the back of the intake valves. So carbon deposits build up from oil blowby in the pcv. In the aftermarket people use catch cans, which have their own downsides and are just a bandaid. The only real solution so far is to have both direct injection and port injection combo, just like this new mustang is supposed to have.
shit post warrior
ITRbroham's Avatar
More or less likely to crash into crowds of people while leaving car shows/meets?
ITRbroham is offline
Old 01-18-2017, 12:41 PM
aka DaZman69!
Definitely more, I suppose the last thing killer mustangs need is more torque
Old 01-18-2017, 12:51 PM
Tickle-shits
Tokyosmash!'s Avatar
Blowby is already an enormous issue with the Coyote, this could end up a **** show.
Tokyosmash! is offline
Old 01-18-2017, 01:01 PM
aka DaZman69!
oh wow didn't know that... carbon buildup?
Old 01-18-2017, 01:17 PM
pogeeboy27's Avatar
A SKYACTIV-G engine is pretty similar to any other engine. It has an aluminum block and cylinder head, with a pair of chain-driven overhead cams. There are four pistons, 16 valves (four per cylinder) and one platinum spark plug per cylinder with a coil-on-plug ignition *system. Nothing unusual here. However, the pistons are domed like a performance piston to raise compression, and have a small cup in the top similar to a diesel piston. The cup acts like a mini-combustion chamber and allows the flame front to spread quickly when fuel is injected directly into this recessed cup in the top of each piston. The cup allows faster combustion and shortens the time any unburned air/fuel mixture in the rest of the cylinder is exposed to high temperatures, thus reducing the risk of detonation.
These engines also use a continuously variable, dual sequential valve timing (S-VT) system to constantly vary the amount of valve overlap as well as the *timing of the intake and exhaust valves. This effectively reduces compression during the intake stroke, as well as pumping losses that would normally occur when the throttle is nearly closed at idle and under light load.
During the intake stroke, the throttle and intake valves are held open while the piston moves down the cylinder. But the intake valves donít close when the piston reaches bottom dead center and reverses direction. Rather, the intake valves *remain open for a brief period as the piston starts back up on its compression stroke. This forces *excess air back out of the cylinder and allows the engine to *behave as if it has a lower compression ratio than it actually does.
http://www.enginebuildermag.com/2013/11/the-skys-the-limit-looking-into-mazdas-skyactiv-engine-technology/
Had to look this up too. Pretty impressive Mazda.
pogeeboy27 is offline
Old 01-18-2017, 01:37 PM
Loves Tossing Salad
09chaplak's Avatar
How many gears can we fit in a transmission? Hmmmmmmmmm
09chaplak is offline
Tickle-shits
Not really because port injection, it literally takes 10 seconds to put a catch can on them though.
Old 01-18-2017, 05:44 PM
Do you even red wheels?
ForceFed Motorsports's Avatar
Not feeling the front end, digging the rear. Performance specs sounds pretty choice.
Smart on the port injection. Don't be Audi haha.
ForceFed Motorsports is offline
Old 01-18-2017, 05:58 PM
Slow*Jim's Avatar
2019 Mustang: 39 gears, shifting every 1.1 seconds.
Slow*Jim is offline
Old 01-18-2017, 06:04 PM
HT White Ops
rochesterricer's Avatar
rochesterricer is offline
