2006 si with 31k miles - Honda-Tech - Honda Forum Discussion
Old 05-21-2018, 09:33 AM
doggydog's Avatar
Default 2006 si with 31k miles
I know this is the wrong forum to post but nothing has been answered in the 06-11 civic forum regarding the third gear issue , since March 2015.
I recently found a 2006 Si with 31,000 miles for sale. I test drove it and it does not grind or pop out of third gear.
My question is if it starts to grind third gear ,will the Honda dealer do the change of 3rd gears free of charge , since there was a TSB ? It is definitely out of warranty since it is a 2006.
Thanks
doggydog is offline
Old 05-21-2018, 09:34 AM
Imgur Lives Matter
90hatch94dsm's Avatar
Default Re: 2006 si with 31k miles
lol @ TSB
Honda will tell you
To
Suck
if you bring that car in for a TSB
90hatch94dsm is offline
Old 05-21-2018, 09:39 AM
I took way too long
slowman's Avatar
Here you go: https://www.scribd.com/document/1577...-Honda-A08-020
Out of warranty:
Any repair performed after warrantyexpiration may be eligible for goodwill consideration bythe District Parts and Service Manager or your ZoneOffice. You must request consideration, and get a decision, before starting work.
Run the GM Synchromesh Friction Modified, worked like a charm in my old 07 Si Sedan I had issues with, after that never a problem. I put it in the Mugen too, even though it was shifting fine.
Amazon Amazon
slowman is online now
Old 05-21-2018, 09:49 AM
doggydog's Avatar
Out of warranty:
https://www.amazon.com/ACDelco-10-4014-Friction-Synchromesh-Transmission/dp/B0026JK8FK/ref=sr_1_1?s=automotive&ie=UTF8&qid=1526924384&sr= 1-1&keywords=ACDelco+10-4014&dpID=41oKLLo409L&preST=_SY300_QL70_&dpSrc=src h
In order to do run the GM Synchromesh Friction Modified , do they need to completely drain oil from tranny ?
Thanks slowman
doggydog is offline
Old 05-21-2018, 09:51 AM
pogeeboy27's Avatar
Just skip 3rd gear. Never ever under any circumstance shift into 3rd gear.
pogeeboy27 is offline
Old 05-21-2018, 09:54 AM
LightningTeg's Avatar
Out of warranty:
https://www.amazon.com/ACDelco-10-40...70_&dpSrc=srch
I use Redline MTL and have not had any issues either
LightningTeg is offline
Old 05-21-2018, 09:56 AM
I took way too long
slowman's Avatar
Thanks slowman
Yeah you just drain it and refill like doing an oil change.. It takes two bottles (like 1.8 quarts or whatever).
Old 05-21-2018, 09:58 AM
I took way too long
slowman's Avatar
Old 05-21-2018, 11:57 AM
Cogent Argument Enthusiast
Uncle Ben's's Avatar
Location: Completing my training with my Supreme Leader
Originally Posted by 90hatch94dsm View Post
lol @ TSB
Honda will tell you
To
Suck
Can confirm, that while they might not use these exact words, this is Honda of America we're talking about here. They will laugh you out the door/off the phone if you expect them to fix **** they fucked up so bad there is a TSB, but not bad enough to cause a class action lawsuit (like the 98-03 v6 trannies).
Uncle Ben's is offline
Old 05-21-2018, 05:09 PM
"Haters Gonna Hate"
FrostyDC4's Avatar
But who was 3rD gEaR VtEc doe!!!!!!
FrostyDC4 is offline
Old 05-21-2018, 05:16 PM
I said I don't want a title!
Other than maybe Toyota taking responsibility for their Tacoma frames (safety issue), I cannot think of one company that would fix a car that's 12 years old, TSB or not (unless lawsuit).
How does OP know that 3rd gear hasn't already been fixed? Did he run the VIN?
Todd00 is offline
Old 05-21-2018, 05:56 PM
Oracle of GDD
Ross's Avatar
Out of warranty:
What was your car doing?
Ross is online now
Old 05-21-2018, 06:46 PM
There is something called a "goodwill repair," and no, Honda will not make one, even on a car thats 3 years old/40k miles, even when the service writer you talk to had the exact same issue on the exact same personally owned car, and is familiar with the TSB; ask me how I know.
I took way too long
slowman's Avatar
the occasional lock out/grind when it was cold in 2nd and 3rd gear. after the trans fluid swap to the linked gm mtf above, it all went away for the duration of my ownership (50,000 more miles after i changed the fluid, never one more trans issue).
Old 05-21-2018, 08:31 PM
Tickle-shits
Tokyosmash!'s Avatar
Honda told me to eat **** in 07' about this, I assume they would do the same to you. GM synchromesh and go about your business.
Tokyosmash! is offline
Old 05-21-2018, 08:38 PM
I collect venereal diseases
ZTwentyH8's Avatar
Like Tokyosmash said, go with GM. Sell that junkball and get a Camaro SS. Bam, shifting issue gone.
ZTwentyH8 is offline
Old 05-22-2018, 04:23 AM
Tickle-shits
I seem to remember your Camaro being an auto, Kenny
Old 05-22-2018, 05:49 AM
Swaggylicious
$amGD3's Avatar
OP the transmission grinding issue is a combination of user error and subpar synchro/ clutch master cylinder design
if it is not grinding currently, the likelihood of it grinding isnt that big especially if you are going to keep it mostly stock
as a precaution, i would change the MTF with Honda MTF (never needed to use other brands in my experience)
if it starts getting notchy down the road, replace the clutch master with the update oem clutch master that they've released
a car with 30k miles shouldnt have these issues
$amGD3 is online now
Old 05-22-2018, 07:33 AM
They were having these issues brand new lol. This isn't your typical trashed synchro we're talking about.
Old 05-22-2018, 07:47 AM
Swaggylicious
$amGD3's Avatar
the 09-11 had updated synchros and then later a new part number for the clutch master cylinder was released. All i know is the grinding was a lot less prevalent on 09-'11s
there were some cases where honda replaced the transmissions on the 06-08s but not sure how true that was
Old 05-22-2018, 08:01 AM
816d16 owes me money!
usdm420's Avatar
usdm420 is online now
Old 05-22-2018, 11:38 AM
ZTwentyH8's Avatar
How many shifting issues did it have? Zero.
I have a 2010 now and it's a manual.
Old 05-23-2018, 03:04 AM
O.G. triple O.G.
NVturbo's Avatar
you should just sell it and get something practical....like a Dodge minivan or something like that. No clutch or manual transmission to worry about
NVturbo is offline
Old 05-23-2018, 07:37 AM
ZTwentyH8's Avatar
Originally Posted by NVturbo View Post
you should just sell it and get something practical....like a Chevrolet Camaro
Old 05-23-2018, 08:51 AM
W95 gives me a hard-on
foumer's Avatar
Redline mtf or Amsoil mtf Op.
foumer is online now
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
