******OFFICIAL GARAGE/SHOP/TOOL THREAD******
Old 05-09-2019, 10:45 AM
  #2301
ky13's Avatar
Default Re: ******OFFICIAL GARAGE/SHOP/TOOL THREAD******
Originally Posted by Caoboy View Post
It's industrial chic you loser. Get with the times.
haha Not sure if this was meant facetiously, but yes!
ky13 is offline
Old 05-09-2019, 10:50 AM
  #2302
-Intl Steve Krew
Caoboy's Avatar
Total sarcasm!
Caoboy is online now
Old 05-10-2019, 09:53 AM
  #2303
ky13's Avatar
silvertaxasteg decided to stick with a single spring (as my door was actually closer to 100 lbs and I didn't want to apply too much tension)
Old extension springs (and ancillary components)
Torsion spring/bar/plates (spring is not wound in the pic)
ky13 is offline
Old 05-10-2019, 01:24 PM
  #2304
#stillneedsadiaper
solsisters's Avatar
How many garage doors you got doe?
solsisters is offline
Old 05-10-2019, 01:48 PM
  #2305
ky13's Avatar
Two (both 8ft x 8ft). The goal is to squeeze 3 cars in there with the lift. Sticking with extension springs/traditional overhead garage door opener on the other side.
ky13 is offline
Old 05-10-2019, 01:51 PM
  #2306
-Intl Steve Krew
Caoboy's Avatar
Don't do that.
You're gonna hate yourself for not getting jackshafts on both doors!
Old 05-10-2019, 02:50 PM
  #2307
ky13's Avatar
Don't do that.
I would go that route if the house didn't already have a traditional opener on the near side. If I ever decide that I need to squeeze 4 cars, I'll definitely make the switch.
ky13 is offline
Old 05-10-2019, 05:00 PM
  #2308
Originally Posted by ScareyH22A View Post
Do they actually have the 4000K model available for sale anywhere?
No idea look on amazon or eBay. I I found this suffering the internet I said that looks cool spent 38$ and really like it my garage donít have the best setup for light this helped.
b16racereg6 is offline
Old 05-13-2019, 09:13 AM
  #2309
I am SO fancy!
silvertaxasteg's Avatar
That's a long spring. Shouldn't lengthen by more than an inch or so, I'd guess. One spring setups last for years, just that they're faster for the home builder. I like the header you built. The pullies look like they are too close inboard, though. I imagine you're still adjusting.
silvertaxasteg is offline
Old 05-13-2019, 03:51 PM
  #2310
ky13's Avatar
Thanks! Yeah! 39" spring. You're right about the drums (they are just sitting on the bar in the pic). They're pushed up against the bearing plates and tightened down now (I left a tiny gap because I wasn't sure if it being flush would prematurely cause the bearing to wear). Just waiting on the jackshaft opener (should arrive on Weds).
ky13 is offline
Old 05-15-2019, 01:55 PM
  #2311
ky13's Avatar
Installed the Liftmaster 8500 today. Also switched to a smalller spring (the other spring was a bit too strong for the door (which only weighs 99 lbs)):
ky13 is offline
Old 05-15-2019, 09:06 PM
  #2312
Steve at Heart
Bently_Coop's Avatar
Sweet small unit, I bet that will help with overhead space.
Bently_Coop is offline
Old 05-16-2019, 05:00 AM
  #2313
ky13's Avatar
Thanks! It's super quiet too.
ky13 is offline
Old 05-16-2019, 06:03 AM
  #2314
-Intl Steve Krew
Caoboy's Avatar
No chains, it's awesome
Old 05-23-2019, 12:44 PM
  #2315
Steve at Heart
My Milwaukee 2763 decided to stop working as I installed a socket to remove axle nuts on one if my Honda's. 7-10 business day turnaround. Hopefully sooner, looks like I'll have to go manual mode now though.
Old 05-23-2019, 01:22 PM
  #2316
-Intl Steve Krew
Caoboy's Avatar
Bought a mityvac vacuum hand pump so I can bleed brakes by myself. Waifu getting tired of pumping lol.
Old 05-23-2019, 01:30 PM
  #2317
RodWolf19's Avatar
I'm tempted to pick one up, gonna do my brakes soon and want to flush the brake sauce at the same time.
RodWolf19 is offline
Old 05-23-2019, 01:35 PM
  #2318
-Intl Steve Krew
Caoboy's Avatar
I got the cheap $40 one off Amazon. They have some fancy stuff. I think Bently_Coop has one
Old 05-23-2019, 02:06 PM
  #2319
Steve at Heart
What car are trying to work on?
I have the attachment for Mityvac MV7201 that doesn't work that good, hard to tell if it seals because of the amount of air in the tube.
I also have a Motive Pressure bleeder with a universal cap and twist on Ford cap. The bottles Motive sells are pretty nice, the hose is real supple.
I would suggest either buying a twist on cap for whatever car or buying a replacement cap and fittings to make one. The Honda version uses a universal with a chain system underneath, problem is if you have a master cylinder under a cowl and access to the reservoir only, it isn't going to seal properly.
Old 05-23-2019, 02:29 PM
  #2320
-Intl Steve Krew
Caoboy's Avatar
Oh so you pump from the reservoir?
I am going to pull from the bleeders
Old 05-23-2019, 11:40 PM
  #2321
Steve at Heart
Pressure bleeding, works pretty good, those pistol vacuum ones look nice too.
This is a much better kit than the Motive.
Old 05-24-2019, 09:23 AM
  #2322
RodWolf19's Avatar
[QUOTE=Bently_Coop;51937365]What car are trying to work on?
The accord in my sig. It needs rears and I figure I'll flush the fluid as much as I can while I'm there. I like the idea of the pressurized option, but I'm afraid of throwing air into the abs unit and never being able to bleed it properly. So vacuum at the bleeder sounds like the safest bet, I imagine it's easier to be aware of how much fluid you're moving.
Old 05-24-2019, 10:14 AM
  #2323
Do you even red wheels?
ForceFed Motorsports's Avatar
What’s the go to for brushless cordless tools?
i need a new impact driver and drill, but gonna have to stick with the brand for everything else I’ll buy in the future.
ForceFed Motorsports is offline
Old 05-24-2019, 10:27 AM
  #2324
LightningTeg's Avatar
Originally Posted by ForceFed Motorsports View Post
Whatís the go to for brushless cordless tools?
i need a new impact driver and drill, but gonna have to stick with the brand for everything else Iíll buy in the future.
Milwaukee Or makita
LightningTeg is online now
Old 05-24-2019, 10:31 AM
  #2325
-Intl Steve Krew
Caoboy's Avatar
[QUOTE=RodWolf19;51937906]
Oh that's simple to get the air out of the ABS, just lock up the brakes a few times (serious)
Quick Reply: ******OFFICIAL GARAGE/SHOP/TOOL THREAD******
