** NEPTUNE BOOST TUNING PACKAGE ** | HAMotorsports.com
This is one of our leading full engine management systems with boost contol and variable boost per gear control. This is by far the most rock-solid, fully customizable, advanced boosted engine management system for OBD1 / OBD1 converted Honda/ Acura setups. We are proud to be the only company offering this fully plug and play (or plug and 'tune') setup! Fully tested with a 90 day guarantee against any manufacturing defects! We are a Neptune authorized dealer and specialize in custom built ECU's so you can rest assured your new ECU package will surpass your quality and performance expectations!
COMPLETE PACKAGE INCLUDES:
* HA Motorsports custom built, fully reconditioned and guaranteed P28 spec OBD1 VTEC ECU. (Features specially socketed ECU for use with the Demon module, along with fully installed and tested PWM boost control components for boost per gear/ ECU controlled boost capability)
* Fully professionally installed and tested brand new, serialized Moates Demon unit
* Neptune RTP software license for use with your new ECU package
* Brand new boost control solenoid with required fittings for electronic boost control
* Full 90 day guarantee against any manufacturing defects on the ENTIRE ECU PACKAGE!
* Add our Innovate MTX-L Wideband for $199 additional and tune yourself either through the ECU's O2 sensor or ELD input, or directly through your laptop with Neptune's exclusive direct serial logging capabilities
FEATURES:
* Seamlessly runs almost any D, B, F, or H series VTEC or NON-VTEC, sohc or dohc engine!
ie: D15B, D16, B16A, B18B, B20, LS-VTEC, B20-VTEC, B18C5 type-R, F22A, H22, and almost everything in between..
* Huge assortment of built-in selectable basemaps within the Neptune software lets you get up and running quickly, or just ask and we'd be happy to pre-load a basemap for you before shipping.
* Plug and play into OBD1 vehicles, can plug and play into OBD2 vehicles with one of our OBD2 to OBD1 harnesses.
* Can operate with or without boost so if you are currently running all motor but plan to add boost in the future you will not have to buy another ECU. Simply install the boost solenoid and map sensor, adjust your settings, and re-tune for boost.
* Fully configurable software for almost any modification you can think of:
- advanced injector sizing, scaling, etc. to run any possible injector you can fit on your engine
- complete VTEC control with advanced load control; set VTEC higher or lower depending on engine load
- launch control, 3-step, anti-lag, and much more
- fully configurable fuel and ignition tables with 24 by 24 grid (much more break points for precise tuning)
- anti theft settings; set a 'secret code' of inputs that you select to allow your car to start, ie: 3 brake pedal pumps, 2 gas pedal, 1 more brake pedal, then allow to start...
- 100% configurable map sensor settings; set to read with the included HA Motorsports 4 bar map sensor, or if you ever need to you can set it to properly read any other MAP on the market.
- up to 12 hours of on board live datalogging and recording for tuning and/or future review with your tuner
- live graphing on 24 x 24 tables, along with display of live sensor data so you can see real-time how your engine is running and check sensor operation (excellent for troubleshooting)
- 4 additional programmable inputs; use additional inputs for wideband setup, etc..
- 3 additional programmable outputs; use for nitrous control, water injection, etc..
- and much, much, much more.. (you will not find a better, more customizable ECU package for your Honda/Acura)
Order online 24/7, or browse our online store for our other ECU packages at your convenience at http://www.hamotorsports.com/combo-package.html. Have a question? Send a quick email to sales@hamotorsports.com
HA Motorsports
