***Stealthmode Oil Line Kits*** (Enter to win FREE ish!!!!)
<FONT SIZE="4">The popularity of our Turbo Oil Line Kit extends to over 1000 happy customers, and we're aiming even higher. Striving to supply you, the enthusiast with the most complete, easy to install, 100% function feed and return for your turbocharged vehicle. Here's how we do it: We start with a custom manufactured Tunertoys.com block fitting that uses the correct 1/8 bspt male threads for your block, with a 1/8 bspt female port out back for replacement of your stock oil pressure sensor, and two 1/8 npt female ports off the side. These ports can be used for turbo feed, vtec head oiling, aftermarket oil pressure sensor, or any other use where oil is needed to be sourced. This block fitting is exclusive to the Stealthmode Performance Oil Line Kit, and is found NOWHERE ELSE. This fitting works with Honda, Toyota, Nissan, Volkswagen, and many other manufacturers.</FONT> http://www.stealthmodeperformance.co...lockfitpre.jpg <FONT SIZE="4">Moving to the stainless lines, we use only the best quality teflon/stainless steel braided lines for maximum durability and reliability. We also only use Stainless hose ends. Each honda/acura kit comes with a 4 ft. -3an feedline, with a 14" -10an drain. Our universal kit for use with many different makes comes with the same 4 ft. -3 an feedline and utilizes a 20" -10 drain for larger mounted turbo's.[size] http://www.stealthmodeperformance.com/oil/feedbig.jpg http://www.stealthmodeperformance.com/oil/dline.jpg [size=4]And the hardware just gets better. We only use the highest quality Tunertoys.com drain flanges. Just one look at these things and you'll understand why we can only offer these pieces for our customers. And unlike other kits on the market, our drain flanges come with gaskets, and only the best hardware. On the drain flange and oil pan connections, we use 1/2" npt barb fittings, and only stainless clamps. No skimping here.</FONT> http://www.stealthmodeperformance.com/oil/kitbig.jpg <FONT SIZE="4">We've created this kit to be the best quality, value, function, and the ease of installation cannot be beat. Other slapped together kits try to compete on price alone, but the quality of parts vs. the cost is the reason why we feel this is the best kit on the market, and it's on sale all month long. https://honda-tech.com/forums/images/smilies/emthup.gif</FONT> click here to order now!!!: http://www.stealthmodeperformance.com/oil.shtml http://www.stealthmodeperformance.com/oil/kitbig.jpg Stealthmode Firewall Kit http://www.stealthmodeperformance.co...irewallbig.gif <FONT SIZE="5">Stealthmode Performance aims to be your number 1 source for all your stainless plumbing needs. If you don't see it, we'll make it. <U>NO MATTER WHAT</U> </FONT> Modified by stealthmode62 at 1:37 PM 2/1/2006 |
"WHERE'S MY FREE OIL LINES?"
Re: (eight5gts)
Re: (mengo_charged)
Re: (lsintegra9)
Re: (SinisterCRX)
please sir... i want some more of: Wheres my free oil lines?
Re: (freakie)
"Where's my free oil lines"
Re: (Average Al)
Re: (stealthmode62)
" WHERE'S MY FREE OIL LINES " ?
Re: (ValleySyder)
Re: (failuretwoyield)
Re: (Jizzmaster Zero)
Please sir I beg of you, I am in desperate need of free oil lines. https://honda-tech.com/forums/images...es/emsmile.gif https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (Bird333)
where's my free oil line kit
Re: (3-hondas)
Where's my free oil lines?
Modified by perlmeister8 at 1:55 PM 1/6/2006 |
Re: (perlmeister8)
STEVE.. WHERE'Z MY FREE OIL LINE AT?
bumpage for TT |
Where's my free oil lines at?
Re: (wpgredteg)
Re: (radam)
Where's my free oil lines ***-nog.
Re: ***Stealthmode Oil Line Kits*** (stealthmode62)
