Zex 59300 (d16z6) in a d16y8 - What to do? (SOHC_MShue - help!)
So my engine is a d16y8. I had a skunk2 cam gear lying around for a z6 and now I want to buy a zex 59300 because I can get one cheap.
So I need to know how to put a z6 cam gear and z6 cam in a y8 head. After reading the archives, I see that SOHC_MShue had a lot of problems with this. How did you finally fix everything?
My main questions are:
1. Do I need to adjust the cam timing by 5 degress even if I am using the z6 gear?
2. What do I need to do about ignition timing?
Re: Zex 59300 (TurboGoKart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboGoKart »</TD></TR><TR><TD CLASS="quote">Why dont you just want to get the Zex 105300?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quagmire »</TD></TR><TR><TD CLASS="quote">now I want to buy a zex 59300 because I can get one cheap.</TD></TR></TABLE>
Re: (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">bu using the Z6 cam into the Y8 u need to adjust it to 4.75 degrees... since both engines are 1/2 tooth off
Even though I'm using a z6 cam gear? I thought it only had to do with where the woodruff key is located.
Re: (QuagmireII)
I have a z6 cam gear and it seems to run great with the cam gear advanced between 4-5 degrees so yea...about 4.75 or a half a tooth.
Re: (SOHC_MShue)
So that's all you did? Seems like you had a hell of a time. Do you have to change the ignition timing also?
And yeah, I wish I could PM, but I'm a newb again . That's why I have four different user names, because the stupid forum software only lets me post 5 times a day with each name
Re: (EnzoSpeed)
yea it took me a while to figure out if that was the right place or not. I just wanted to make sure it was right. It still seems like it should be off to me because it is a z6 cam and a z6 cam gear, but i've tried a bunch of different settings and this seems to be the best. As for ignition timing make sure that you have a timing gun handy to readjust it after adjusting the cam timing.
CivicMike
05-31-2006 09:43 AM
Daniel
17
10-24-2003 09:55 AM
