y8 turbo graphs built block(just for kicks)
Old 05-11-2007, 04:52 PM
BearsEK-KMSU's Avatar
Default y8 turbo graphs built block(just for kicks)
Heres the build:
y8 block
eagle rods
wiseco shelf pistons
.040 off the head
.030 head gasket
crower springs valves retainers
crower turbo cam
crower cam gear
skunk2 pro-series intake manifold
hondata intake gasket
bored tb
AFI ram horn
garret t3/t4 .63 a/r 57 trim .60 compressor a/r
average intercooler
3" DP and thermal 3" exhaust no cat
Hondata s300
93 octane
Blue low boost 9 lbs
Red high boost 18.5 lbs
Old 05-11-2007, 05:43 PM
1_bad_EF's Avatar
Default Re: y8 turbo graphs built block(just for kicks) (bearsEK)
HiProfile's Avatar
For all that, I woulda just gone na b20/vtec! Seriously though, thats a lot of stuff for a sohc. Was the head ported at all?
It spools up nicely and holds torque a lot better than stock-head d16's. If you said that was a conservative tune, does that mean there's still more left in the pump gas for this motor? I know you guys do dohc's past 20psi on pump, just curious if this could hit 400 on 93.
BTW ever try anything on E85 yet?
Old 05-11-2007, 06:03 PM
Default Re: y8 turbo graphs built block(just for kicks) (HiProfile)
I could have turned up the boost with his compression being pretty low but i didn't want to push it after all its a single slapper. I haven't messed with e85 yet i have thought about it tho.
Old 05-11-2007, 08:18 PM
Jose-aka-Pedro's Avatar
Nice.
Pics!
Old 05-12-2007, 03:34 PM
sohc_vtec 2NR's Avatar
so far its good for 12.0 @ 117...
Modified by sohc_vtec 2NR at 1:00 AM 5/13/2007
Old 05-12-2007, 05:23 PM
HiProfile's Avatar
Default Re: y8 turbo graphs built block(just for kicks) (sohc_vtec 2NR)
After watching this car at the dyno and then getting numbers on my d16/t3, I'm definately going to weld up a 3" exhaust for it now.
Old 05-12-2007, 07:24 PM
THEDirtyDseriesWOOT's Avatar
we tuned a d16z6 on 93 made 402whp at 18psi on a sc61 he had alot of port work by rlz done though..
Old 05-14-2007, 09:06 PM
EJ8Joel's Avatar
Default Re: (THEDirtyDseriesWOOT)
i ate 30 hot dogs in an eating contest , nice graph too
Old 05-14-2007, 09:13 PM
Default Re: (EJ8Joel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8Joel &raquo;</TD></TR><TR><TD CLASS="quote">i ate 30 hot dogs in an eating contest , nice graph too</TD></TR></TABLE>
so your the reason we ran out of hot dogs during dyno days!
Brundell88
Appearance Build Threads
01-16-2013 07:01 AM
zcrx2006
03-28-2009 11:08 AM
jaydem_ekizzle
08-20-2006 07:52 AM
chippy
12-02-2004 02:20 PM
Pfieff
08-21-2004 06:24 PM
Quick Reply: y8 turbo graphs built block(just for kicks)
