WS or N1 for SOHC TURBO?
hi i wanted to kno wha exaust setup is better for a sohc turbo.. WS or n1 .. also which one of the edelbrock turbo is better for the z6... the performer x or the open track turbo.. plz help me out here.. thanx!
Re: WS or N1 for SOHC TURBO? (JDMnerd)
i ran the ws on my z6 turbo for a few weeks, boosting 6 psi. i never dynod with the turbo or anything, but i feel the exhaust was adequate, plus it was fairly quiet which is a plus. roughly, i would say that low boost the ws is fine, but once you start getting into higher boost the straight through design of the n1 would be beneficial
oO ic .. i was thinkin bout runnin 10psi for starters.. untill i really get into the high boosting
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMnerd »</TD></TR><TR><TD CLASS="quote">oO ic .. i was thinkin bout runnin 10psi for starters.. untill i really get into the high boosting</TD></TR></TABLE>
ok then i would say to pass on the ws. if you seriously plan on running a decent amount more then 10 psi you might even consider either custom piping to a muffler such as the magnaflow, or maybe look into the n1 turbo muffler, which comes with like 3 inch piping instead of the na spec which is like 2.36 inches or something like that |
Re: WS or N1 for SOHC TURBO? (blackeg)
just get a muffler that has 3 inch inlet and buy a piping kit from kteller https://honda-tech.com/forums/images...es/emsmile.gif
Re: WS or N1 for SOHC TURBO? (B18C1CYA)
dam those are good ideas thanx guys! i do like the sound of the n1 turbo... well keep em coming https://honda-tech.com/forums/images...es/emsmile.gif
ok soo n1 wit 3 inch piping sounds good.. but what about the n1 dual ? should i consider that?
i would just do singel muffler
