would u use rings other than honda?
Would you guy's use any other piston ring that a honda?
Basically the honda rings for my block are $55 canadian per piston. But I can go to Canadian Tire and buy a complete set for $55 canadian. I know that honda OEM is best, but I mean there is a big price difference.
The #1 piston and rings are toast. The other cylinders are great, hardly any ridge and I can still see the cross hatching. Would I be just wasting my time putting in non oem rings if the block diden't seem to need them? I'm just thinking ya know now that I have it appart and what not (mind you the block is still in the car). If not I'll just buy honda oem rings and put the #1 piston back together.
The same goes for the rod bearings.
Advice please from all you experienced builders.
Re: would u use rings other than honda? (Hybrid)
since you're already changing out 1 set of rings, you should go ahead and change the other 3 as well. dont be cheap in this area
I agree. Don't be cheap on this one. Get the Honda rings, and make sure you hone the cylinders so the new rings will seat.
