would an ACT xtreme pressure plate and street/strip disc hold up?
im running an ls turbo in my eg and its at 7psi right now but i turn it up to 10 psi at the track....would an ACT xtreme pressure plate and street strip disc hold up ok?....i dont like the chatter and harsh engagement on the 6 puck disc
Re: would an ACT xtreme pressure plate and street/strip disc hold up? (kun3racer)
mine held up for like 3 years on NA, Juice and then boost. Its rated at 320ft lbs, so im sure youll be more than fine.
Re: would an ACT xtreme pressure plate and street/strip disc hold up? (troublecodes)
Thats what I've been running on mine for the last 3 years (24k miles).
It's holding 12-13psi just fine rite now.
Re: would an ACT xtreme pressure plate and street/strip disc hold up? (b16ahybrid)
Yeah the Act Xt/ss is plenty enough. **** if your only going to run 10 psi, you might even get away with the Hd/ss which is rated to 240 ft lbs, but if you plan on making more power later the Xt/ss is the way to go
Re: would an ACT xtreme pressure plate and street/strip disc hold up? (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B »</TD></TR><TR><TD CLASS="quote">Yeah the Act Xt/ss is plenty enough. **** if your only going to run 10 psi, you might even get away with the Hd/ss which is rated to 240 ft lbs, but if you plan on making more power later the Xt/ss is the way to go </TD></TR></TABLE>
StreetwizeRacin2
11
03-30-2004 03:53 PM
TheShocker
09-08-2001 01:17 PM
