worth it or time bomb? need sleeve help
Old 01-24-2008, 05:15 PM
eflove's Avatar
Default worth it or time bomb? need sleeve help
I am looking for a motor and was told I could have this ls for free. Poped off the head and find this. running the car with lack of coolant ate away at the top of the sleeves in a few spots but only the out side layer of AL. The inside I guess iron part is fine. Now my question is will the lack of outside layer in a few spots weaken it or is that layer just for heat transfer? could I weld it back up to fix it? Will that hurt the head gasket seal? It will be boosted to the tune of 300ish.
Old 01-24-2008, 05:51 PM
Mr. Badwrench
boostedcivicsir's Avatar
Default Re: worth it or time bomb? need sleeve help (eflove)
300 ish?
pic # 2 is telling me no.
sleeve it, have it there for the future if you can swing it.
Old 01-24-2008, 05:56 PM
eflove's Avatar
Default Re: worth it or time bomb? need sleeve help (boostedcivicsir)
I want to stay oem it will be a ls-v. you dont think it could be rewelded?
Old 01-24-2008, 06:02 PM
Mr. Badwrench
re welded i dont think so, i think the heating then cooling / contraction will warp it. but i am not a machinist.
Old 01-24-2008, 06:14 PM
eflove's Avatar
oh sorry I know the heat will warp it a bit but a bore and hone is alot cheaper then a resleeve. Does it need to be done at all? I mean I dont see it as weaker now as its at the top but will a headgasket seal is what im thinking.
Old 01-24-2008, 06:20 PM
Mr. Badwrench
the head gasket is what i would be worried about. there is less for it to bite to.
weemanch
01-14-2008 11:26 AM
Fliplm0de
08-15-2006 09:30 AM
jdm_ef9
04-21-2004 11:10 AM
juicedricer
05-26-2003 11:10 PM
pbomers
11-18-2002 07:22 PM
Quick Reply: worth it or time bomb? need sleeve help
