wont start: not sure whats wrong: info inside --->
Well... I got my turbo installed and only have a basemap on it... and you guessed it... I ran it fairly hard today. To put it as simply as i can.. I was at about 6-7k and it goes BOOM and a small cloud of black smoke goes out the back. Then it shuts off.
I originally thought that I either snapped a rod/ring lands were fried/ or bent a rod. However.. It cranks but wont turn over. SO I did a compression check. All are within 20 psi of eachother at around 180 (was like that before I went turbo). No really loud noises or anything when I go to crank it so I doubt its anything internal. (not sure tho).
SO.. that kind of leads me to believe that its my timing belt. I thought my belt could have skipped some teeth or something. I took the valve cover off and couldn't tell much from there. Is it possible for the engine to do something like that and not start up? Or did I seriously **** something up? .
After all of this is done... I will NEVER drive another car unless it is properly tuned.
Mr. Badwrench
Re: wont start: not sure whats wrong: info inside ---> (Mugen112)
if your belt jumped, chances are your compression would be all out of whack.
look at your plugs, make sure they arent melted. check the basics:
fuel - air - spark - compression - proper timming
Re: wont start: not sure whats wrong: info inside ---> (boostedcivicsir)
^^^What hea said^^^
Sucks learning the hard way.
Honeslty before you go ripping things apart do a leakdown test as well as check the coolant, dain the oil and check for metal. You could even pull the oil pan and remove he windage tray and have a look around.
[713]
05-14-2012 03:23 PM
