wiring up rc injectors to obd2 wire harness
Old 03-11-2003, 02:27 PM
lsvtec101's Avatar
Default wiring up rc injectors to obd2 wire harness
which wires go where ?
Old 03-11-2003, 02:55 PM
CM-R's Avatar
Default Re: wiring up rc injectors to obd2 wire harness (aemcivic_02917)
First you need new clips...because rc requires ODB 1 clips
Old 03-11-2003, 03:02 PM
lsvtec101's Avatar
Default Re: wiring up rc injectors to obd2 wire harness (CM-R)
already got them on look in the pic
Old 03-11-2003, 03:08 PM
CM-R's Avatar
oh ok in that case...just copy the old connectors the way they hooked up orginally and solder them....thats basically it
Old 03-11-2003, 03:21 PM
Sleepin''s Avatar
Make sure the yellow/black wires are facing the timing belt. Dont mix up which wires go to which injector!
08-30-2005 02:19 PM
eatbieodie2
04-25-2005 09:58 PM
booscivic
02-15-2004 05:26 PM
chuckd05
12-27-2001 10:00 PM
redline
08-12-2001 09:27 PM
Quick Reply: wiring up rc injectors to obd2 wire harness
