Will A top Mount Manifold and a S372 Fit in My DA
Hello,
I am looking at getting a Full Race Top Mount Manifold and a S372 turbo for my Car. I have a 1991 Acura Integra with a LS vtec built and ready to go. I am worried that I am going to have some clearance issues with the upper and lower cross members.
Can you guys show some pictures or let me know if this can be done. I was looking for the Full race Twin Scroll bottom mount that was made some time ago now that was developed to run large turbos even in a CRX. I checked there site and cannot find the manifold any longer.
Thanks in advance!
Thanks in advance!
Re: Will A top Mount Manifold and a S372 Fit in My DA
da's are tight and with that big of a turbo and a top mount consider it not fitting without openign up the hood liek stated above
I would hate to run a Log style Manifold for this Turbo but Im set on getting the S 372 Ill look areound to see what else is compatable but can fit a top mount for me any sugestions
I never thought That turbo with a top mount would touch the Hood. Once mounted does the Turbo not sit about flush or a bit below the Valve cover. Most pictures look that way when on a B series motor.
is this a built drag car or just a personal use car cause quite honestly thats alot of turbo for a street car and to be so worried abotu running it. is it just a wow factor or you are going to race this thing? I dont knwo the setup but with that turbo i hope you've got one heck of a driveline in the car tranny and axles lol
The motor is built but will be a street/race car I just don't want to buy a turbo max out and buy another it's a waste of money however I just did some reading and the s366 sounds good to me plus Slowboy90 is running a top mount with a S366 and fitment was good probably go that route. Slowboy is running A sls top mount with it I wonder if a full race would work?
Moderator
You're at a point to purchase, find out, and be ready to fab if necessary. Ask Slowboy 90 which company he used. I would not be surprised if it was custom fabbed. We're not saying it won't work, we're saying that there may be more involved than anything "bolt up".
I also like the Precision 67 billet series for that power, and can make similar power in a standard T04S cover
Thanks for your feedback according to slowboy he is running a normal sls to mount as you said it's a tight fit in the DA integras but I think the positioning with the sls top mount is a bit different then thefull race turbo is basically less then a inch from the head when using the s366 I will most likely call sls or full race and tell them what I will be running to be safe
thats what i did i called the guys over at SLS and we spoke he was 100% sure they had personally cleared a s362 so i figured it would be close and they cut me a deal as well. but quality of the manifold is top knotch
i just re read your post if your worried about the lower crossmember i dont think you so run a top mount lol because you will need a traction bar setup or a aftermarket crossmember to clear the downpipe needed for a large frame turbo
Slowboy thanks for your feedback just to be clear I'm less concerned with the lower crossmember as I will be purchasing an after market one I was concerned with hood clearance and fit ment from the head to the upper crossmember that the headlight bolts to I will call sls I want to run there twin scroll dual gate set up but a top mount us a too mount if the could make yours fit they can run the similar design for the twin scroll thanks the pictures would help if you can find some lol
I had a Boostwers DA top mount that I had to return because it wasn't compatible with any other chassis. I bought it brand-new second hand from a DA owner to use in my EK. Bryson was nice enough to give me partial credit on the return (even though I didn't buy it from him) and probably still has it.
Hit him up at:
Boostwerks@hotmail.com
Here it is mocked up in a DA with a Holeset turbo from the original owner (TallKyle)
And the replacement he made for me:
Hit him up at:
Sweet Looks like a Sick Manifold especially if it was mocked up in a DA. I wish it her a Twin Scroll though I believe the S366 is a divided housing so not sure how effective it will be. I have e mailed him to ask about pricing anyways. Thanks Allot Bro!
I also have sls topmount with S362 with backdoor FMIC, mani and turbo fit fine, But still had Fab. dual 38 gates for creep issues and snake dumptubes under it all, i have pics if ur in need, otherwise its all custom not like turbo kit u buy and bolt together in DA., and fitting 372 NOWAy lol, had friends turbo and test fitted it in my mani, hits head and hood, unless you build a mani just for it,
i sent you pics man of my set up lemme know if i need to send them again, btw i also run a back door IC i fabbed it up but its still back door
i got the core from treadstone its there race core 4.5in thick then me and a friend started making the tanks
