will a TIAL BOV work if im only running 5-10 psi?????
i got a tial bov with a 7 psi spring, but will it release pressure if im only running 5-10 psi??? the spring is really tight and hard to push in. would appreciate any feedback
civic si turbo
civic si turbo
Re: (1baddturbosi)
Tial doesn't rate the spring pressure on the blow-off valve to what psi you run, rather to what vacuum you pull at idle.
http://www.tialsport.com
Engine Vacuum Reading Use Spring
-22 and -23 in/Hg -12 Psi (-24 in/Hg )
-18 and -21 in/Hg -11 Psi (-22 in/Hg )
-14 and -17 in/Hg -9 Psi (-18 in/Hg )
-10 and -13 in/Hg -7 Psi (-14 in/Hg )
Re: (1baddturbosi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1baddturbosi »</TD></TR><TR><TD CLASS="quote">ok, so what do yall think i should do?</TD></TR></TABLE>
see how many in./hg of vac you're pulling and get the right spring for it...
Re: (mike93eh2)
The Tial needs to have a vacuum line from a large vacuum port and the line needs to be high quality and not colapse. I ran one on my turbo Miata and even at 3.5 psi it would blow off clean and crisp......once I installed larger vacuum ports into the intake manny.
yes sir at idle . I mean my car was a one owner car . Got it when it had 78,000 miles on a 90 da. Old man took care of this bitch. So what spring should i get
ThePro
06-30-2005 04:43 PM
