will a tapped b18a oilpan fit my jdmb16?
looking to buy a turbo kit from a local and it comes with a tapped b18a oil pan...
just wondering if it will fit and work properly on my jdmb16?
i hope this was the right forum. haha
thanks...
thanks...
Re: will a tapped b18a oilpan fit my jdmb16? (OBRJosh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBRJosh »</TD></TR><TR><TD CLASS="quote">Yes it will</TD></TR></TABLE>
+1
+1
Re: (myEK=slow)
All b series oil pans will fit all B series engines.......go to autozone and check the part number and see if they match for all B series engines.
Re: (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy »</TD></TR><TR><TD CLASS="quote">All b series oil pans will fit all B series engines.......go to autozone and check the part number and see if they match for all B series engines.</TD></TR></TABLE>
your statement isnt totaly true. Yes all B pans will bold to B blocks.. But the oil pick ups are different on gsr motors... the pans are deeper and the pick up is longer.
can someone confrim what pans fit what blocks... and oil pick ups. ?
Re: (adseguy)
ever try to put a B16 pan on a GSR? yeah it doesnt work unless you change the pickup on the GSR block
Re: (MoonScryer)
ok well as a basic bolt on, yeah the pans fit, holes are the same.
the pickups are a bit different, so you have to match that to the pan.
Re: (pornstarSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pornstarSR »</TD></TR><TR><TD CLASS="quote">ok well as a basic bolt on, yeah the pans fit, holes are the same.
x365
x365
Re: (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 »</TD></TR><TR><TD CLASS="quote">
ever try to put a B16 pan on a GSR? yeah it doesnt work unless you change the pickup on the GSR block </TD></TR></TABLE>
X 24-7
X 24-7
Re: (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">X 24-7 </TD></TR></TABLE>
hahaha shouldnt that be 24-6 for you? j/k
Re: (SiDonny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiDonny »</TD></TR><TR><TD CLASS="quote">i'm using a b18a/b oil pan on my b16 i didn't change my pickup.. </TD></TR></TABLE>
the only time you need to change the pickup is when you use a B16 pan on a GSR block
