will saturated injectors work in an OBD-0 car?
i'm 99.9% sure that if i elminate my resistor box, that my ecu will support saturated injectors, correct? can someone back me up on this?
thanks
thanks
Re: will saturated injectors work in an OBD-0 car? (b18bturbo)
well ks motorsports has the 440s for like 260 shipped. however, they do not carry the peak-hold form. does anyone know where i could get (4) peak hold RC 440's for cheap?
thanks
thanks
Re: will saturated injectors work in an OBD-0 car? (keebler65)
thanks
thanks
we have the delphi 440cc peak and hold 200 + shipping
Re: will saturated injectors work in an OBD-0 car? (Sonny)
You can run Saturated injectors on an ECU that requires Peak and Hold. You just can't run Peak and Hold ones on a Saturated ECU. Basically this is because the resistance is what matter to the ECU. If your ECU expects to have enough resistance for Saturated then if you put less resistance you'll blow the injector drivers. But since Peak and Hold injectors have less resistance then the Saturated ones, if won't matter if you put Saturated injectors on a Peak and Hold ECU. Does that make sense to you...?
Baiscally, Peak and Hold ECU = Peak and Hold or Saturated injectors. Saturated ECU = Saturated injectors ONLY.
Hope this helps...
Hope this helps...
Re: will saturated injectors work in an OBD-0 car? (JRSCCivic98)
Yep...I ran saturated injectors on my OBD0 DA for a while and had absolutelly no problems. HTH
-Ryan
-Ryan
Hope this helps...
Hope this helps...
Jason
Re: will saturated injectors work in an OBD-0 car? (Blown90hatcH)
That's because people with OBD0 setups already have resistor pack installed into the wiring harness. They can run either injector.
Sonny
Sonny
I was refering to his statement about...
That is untrue about the ecus. Also, to run the OBD1/2 injectors in the OBD0 setup, you have to solder the wires together when removing the resistor box. Or basically close the loop.
You can run the saturated ecu along with the peak and hold injectors. Your statement says
That makes me think that I can not run the peak and hold injectors with the saturated ecu. That is untrue. Add the resistor box and you are fine.
GForceInteg
04-19-2004 03:07 PM
