Will this exhaust be nasty loud?????
Setup is a 1.5 sohc with a t3.
Im in the process of making a 3 inch downpipe. And gonna order the 3 inch mandral bent del sol piping kit, a 22 inch resonator, and a magnaflow turbo muffler. I wont be running a cat...Just the 22 inch resonator, maybe two of them if its loud.
Will this be nasty loud? Anyone have similiar setup on sohc? soundclips maybe?
Re: Will this exhaust be nasty loud????? (BoostedD15B7)
That's what I am running but I need to hook up the DP to the exhaust still. I'll let you know how loud it is once I do that. When I was N/A it wasn't that bad...
everyone on here says 3" isn't that loud......but I'd have to disagree......it's fucken loud.....turbo muffles some of it...but not that much......good luck with your setup
Re: Will this exhaust be nasty loud????? (mamaboy)
hmmm...the resonator im gonna use is 22 inches long....maybe if its loud i can put two of those in a row...
here is a pic of my setup and it is pretty damn loud. But in all honesty if you have to drive the car everyday, which i don't, then id do the best flowing exhaust possible for a turbo application.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedD15B7 »</TD></TR><TR><TD CLASS="quote">hmmm...the resonator im gonna use is 22 inches long....maybe if its loud i can put two of those in a row...</TD></TR></TABLE>
Good idea if they will fit. The system for my ITR has two resonators, but they are not hooked together. One is back by the fuel tank.
Re: Will this exhaust be nasty loud????? (TheShocker)
Well I got it hooked up tonight. It's really fricken quiet to be honest... Thermal 3" with 22" 3" resonator.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShocker »</TD></TR><TR><TD CLASS="quote">That's what I am running but I need to hook up the DP to the exhaust still. I'll let you know how loud it is once I do that. When I was N/A it wasn't that bad...</TD></TR></TABLE>
none, i have a similar setup with the t3, no resonator it's loud when it's WOT but underboost it's okay loud.
1 Post
Re: Will this exhaust be nasty loud????? (iam7head)
every turbo car that Ive had has never been loud. All have either had straight 3 inch dumps or 3 inch exhausts. Maybe Im just used to straight 2.5inch pipe on LSVtec? I know....Im fuking deaf...
Re: Will this exhaust be nasty loud????? (HybridcivicLS-T)
I am getting my stock exhaust/cat swapped out for a no-cat 3" system with a Flowmater Deltaflow 40 muffler on Monday. I will let you know how it sounds. If it is loud I don't really care, there are a lot of loud *** trucks and V8's around here. It would be funny to be mistaken for one of those before someone sees me!
Re: Will this exhaust be nasty loud????? (BoostedH23a1)
im running 3 inch and a high flow cat to a straight through magnaflow muffler. Its way more quite then when i was N/A. the tone change. it got deeper and no more raspy sounding. driving around town is quite but when i get on it it fucken screams.
Im running 2.25" pipe, i still have stock cat but no resonator, all leading to an A'Pexi N1. This setup is ******* LOUD AS ****, what can i do to calm it down.
Re: (FBP Si 2000)
i bet mines gonna be hella quiet... 22" resonator.. then to a Y pipe back down to 2.5 inches then i have mufflers to quiet it down. hehehe
Re: (BoostedH23a1)
my turbo car sounds no where near as loud as my n/a car (2.5" straight pipe)
i have 3" dp, 3" cat, 3" pipping then go 5zigen fireball turbomuffler..sounds like stock if you ask me
Jeff-
Jeff-
trooper0641
10-18-2004 01:00 PM
