Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   Will this effect spool? (https://honda-tech.com/forums/forced-induction-16/will-effect-spool-2254602/)
BigWang Mar 19, 2008 12:31 PM
I have a borg warner s366, and the turbine has a 4" outlet. Will it effect spool or anything negative if I run a transition from 4" to 3" from the turbine. Basically, use a 3" dp instead of a 4" dp.
SovXietday Mar 19, 2008 12:41 PM
Re: Will this effect spool? (BigWang)
Yes, it will make it spool slower. If you need to transistion from 4-3 do it at the end of the DP.
