Will 0.6bar / 8.6psi be enough for my goals?
My tial wastegate has a 0.6 bar spring and I was wondering if that is enough to get me to my goal so then I can decide if I should hook up my mbc or just run off the spring. I will be having this street tuned so I don't want to have it tuned, dynoed, then find out I'm not at my goal and have to re-tune and dyno it again. My goal is 210-220whp. Here's the setup:
stock y7/y8 mini me
T3 .60 trim .48 exhaust
spoolin log mani / 2.5" dp / closed-loop dump
2.5" carsound high flow cat / 2.5" catback / 2.5" straight through muffler
Tial 38mm wastegate
1g DSM bov
dsm 450cc injectors
2.5" charge pipes
CCA 6" fmic
chipped p28 w/ crome
stock y7/y8 mini me
Tial 38mm wastegate
1g DSM bov
dsm 450cc injectors
2.5" charge pipes
CCA 6" fmic
Re: Will 0.6bar / 8.6psi be enough for my goals? (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GiNuWiNe »</TD></TR><TR><TD CLASS="quote">You'll need anywhere from 10-13psi for your goals...</TD></TR></TABLE>
Re: Will 0.6bar / 8.6psi be enough for my goals? (EndlessDc2)
You should hook up a ball and spring MBC anyway..completely delaying the signal to the WG will help boost response tremendously.
Redwidow
02-24-2007 10:38 AM
