Why does my PLX-300 only read 14.6
so i finally got my car running but the POS wideband doesn't work it stays at 14.6 and moves +/- .7 . I tried a couple diff sensors its the same thing.. What else should i look for.
Re: Why does my PLX-300 only read 14.6 (CashmoneyUKR)
That is what the wideband should read if there isnt any sensor hooked up. If you have verified that both wideband sensors that you've used are good, then the unit itself may be defective. That is really all you CAN do.
we arent talking about the sensors here, the actual unit that converts the signal might be faulty, call up plx and see if they can fix it
