why do people use check valves when you can just...
tap into the vaccum line off the tps sensor that goes to the black box. the tps sensor is the little <=> shaped thing with the cylinder on top on the right back of the intake manifold. rofl worst diagram ever. anyway... the line that goes off this never will read boost it always reads vaccum ... couldnt you just run your map sensor inline to this line?
if im completely wrong lmk
sam
sam
Re: why do people use check valves when you can just... (94goldjungsr)
I dont have a clue what your talking about, but id say your wrong.
The TPS is the throttle position sensor, and does not have any vacuum lines to it.
A. i think you're talking about the idle air control valve, not the TPS. there is no vaccuum involved with the TPS, only throttle plate angle.
B. doesn't matter where the vaccuum source comes from, when that throttle plate is open, the whole system post compressor sees boost.
Re: why do people use check valves when you can just... (filthy scarecrow)
no no not the iacv. the little black cylinder thing on the back of the IM that goes to the black cylinder which is below the battery.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy scarecrow »</TD></TR><TR><TD CLASS="quote">A. i think you're talking about the idle air control valve, not the TPS. there is no vaccuum involved with the TPS, only throttle plate angle.
B. doesn't matter where the vaccuum source comes from, when that throttle plate is open, the whole system post compressor sees boost. </TD></TR></TABLE>
im telling you right now that the line from this device never sees boost for whatever reason... we put a boost gauge on it and it wouldnt read boost, just vaccum. when boosting itd read 0
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr »</TD></TR><TR><TD CLASS="quote">no no not the iacv. the little black cylinder thing on the back of the IM that goes to the black cylinder which is below the battery.</TD></TR></TABLE>
i think he is talking about the evac/purge valve????
Re: why do people use check valves when you can just... (The Brown Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Brown Kid »</TD></TR><TR><TD CLASS="quote">putting in a check valve seems easier</TD></TR></TABLE>
It would when you dont know what I'm talknig about LOL...
Re: why do people use check valves when you can just... (SOHC Beast)
He's talking about the line that runs from the throttlebody to the charcoal cannister. Yes, the evap/purge line. That's all I know.
hes talking about the PCV valve on the back of the block it does have a check valve in it, and it owuld work, but its a pain to get to w/out removing the intake manifold. Might as well have them tee off the brake booster line after the check valve, much easier.
Re: why do people use check valves when you can just... (Buraku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buraku »</TD></TR><TR><TD CLASS="quote">hes talking about the PCV valve on the back of the block it does have a check valve in it, and it owuld work, but its a pain to get to w/out removing the intake manifold. Might as well have them tee off the brake booster line after the check valve, much easier.</TD></TR></TABLE>
. on the back of the intake mani. not block!
Pariah
10-20-2005 02:35 AM
