Whos running the most Hp here on 550's?
Smarter than you
Re: Whos running the most Hp here on 550's? (itr206)
at stock fuel pressure Josh(hybrid901) maxed out his 550's at about 375whp w/ a 60-1 hifi turbo gsr @ 17lbs of boost.
(100% duty cycle) 4 * 550cc/min = 2200cc/min -> 3.489lbs/min -> 209.35lb/hr.
<FONT COLOR="blue">Lean</FONT> 209.35lb/hr / 0.45lb/hp/hr = 465.22hp
----- 209.35lb/hr / 0.5lb/hp/hr = 418.7hp
<FONT COLOR="red">Rich</FONT> 209.35lb/hr / 0.55lb/hp/hr = 380.64hp
Re: Whos running the most Hp here on 550's? (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg »</TD></TR><TR><TD CLASS="quote">with a 12:1 FMU a few of my friends on 440s have hit 500 whp at 22lbs</TD></TR></TABLE>
Thats Awsome! I'm running that same fuel setup on my car right now and it drives perfect, no stumbles or bogs. 96 EK, Stock GSR, Skunk 2 manifold, DRAG III, 9 psi = 12.34 @ 110 mph
Re: Whos running the most Hp here on 550's? (Muffin')
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muffin' »</TD></TR><TR><TD CLASS="quote">(100% duty cycle) 4 * 550cc/min = 2200cc/min -> 3.489lbs/min -> 209.35lb/hr.
<FONT COLOR="red">Rich</FONT> 209.35lb/hr / 0.55lb/hp/hr = 380.64hp</TD></TR></TABLE>
Being an engineer i appreciate those calculations, although i haven't looked through them. Looks good
Re: Whos running the most Hp here on 550's? (Chrome Pipes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chrome Pipes »</TD></TR><TR><TD CLASS="quote">
Thats Awsome! I'm running that same fuel setup on my car right now and it drives perfect, no stumbles or bogs. 96 EK, Stock GSR, Skunk 2 manifold, DRAG III, 9 psi = 12.34 @ 110 mph</TD></TR></TABLE>
sweet. thats why i love FMUs, but you cant beat a good engine management program either, lol...
damn i cant believe all that on an fmu, thats sick .
the reason why im asking is becuase im building up my motor in a few weeks, and wanted to get an idea what i can get out of these things before i sell them for bigger. with the engine build up , i wont have money left for injectors for a little
0.45lb/hp/hr
0.5lb/hp/hr
0.55lb/hp/hr
I follow the other part, but how do you establish these numbers? Would these numbers apply to all engines? Or were they calculated just for itr206's type of car?
0.45lb/hp/hr
0.5lb/hp/hr
0.55lb/hp/hr
Re: Whos running the most Hp here on 550's? (95GS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GS-R »</TD></TR><TR><TD CLASS="quote">
I follow the other part, but how do you establish these numbers? Would these numbers apply to all engines? Or were they calculated just for itr206's type of car?</TD></TR></TABLE>
It comes from the enthalpy of reaction, meaning that 209lb/hr of gas, when burned has a certain amount of energy and depending on the temperature (rich or lean) you can get more or less energy from the burn. then since an engine isn't a perfectly effecient machine you multiply that number by a the effeciency of the engine, which should be the about the same give or take for any 4 cylinder. I would say if those numbers are accurate, they should apply to any engine, give or take a few hp. Hope that helps, I'm studying this stuff right now and just had a test......im sure I'll forget it all in a few days....haha.
Evan
Evan
http://www.rceng.com/technical.htm
At the bottom of the page, there is a handy calculator that will give you an idea of the size of injectors you need to support a given horsepower number.
how can this be possible?12*22=264+50psi stock pressure=314psi fuel rail pressure @22 psi!
Re: Whos running the most Hp here on 550's? (11sec.sleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11sec.sleeper »</TD></TR><TR><TD CLASS="quote">
who cares how its possible, it is...
that setup consists mostly of inline pro guys...
Tr0LL
09-14-2001 10:54 PM
