whoa the flange on the exhaust side of my turbo is wierd as hell
Re: whoa the flange on the exhaust side of my turbo is wierd as hell (sutrusu)
or am i going to have to weld some ****... turbine on it is from 300z compressor is from saab..
You can probably get a standard T3 flange and drill some new holes in it...but that is some funkiness.
Actually it may be that that is a standard T3 with a couple of extra bolt holes...
[Modified by mplex2000, 11:05 PM 8/9/2002]
Re: whoa the flange on the exhaust side of my turbo is wierd as hell (mplex2000)
im thinking that standard t-3 flange will fit it, get one and try it out.
or you can take it to a machine shop and they can whip one up for you, if i was closer i would try and make you one.
Rob
Rob
Re: whoa the flange on the exhaust side of my turbo is wierd as hell (rjardy)
rob do you do good work? i dont plan on having the turbo in until june of next year, so i have plenty of time. if i cant find anyone to machine one for me i might have to ship this bad boy over to cali...
doesn't that look the same to you, just with a couple extra bolts? if so, it just has some extra holes drilled in and i could use a drag downpipe...
[Modified by sutrusu, 12:56 AM 8/10/2002]
yeah i can make a flange for that, i wont be home untill november (in Korea right now) and home is where the shop is. If you want you can send me a template of it, but it would be better to have the peice so i know that it fits. let me know what you want to do.
Rob
Rob
i am very new to the whole turbo thing... this flange.. does it act as a gasket between the downpipe and the turbo, or what.
thanks
thanks
no the flange, the peice i was talking about making you is actually the start of the down pipe, its going to have a hole in it where the turbine is and then thats where you plumb your exhaust tubing to. hang on i will post a pic
thi is a regular t3 peice, yours would look just like this but have two extra holes in it.
Rob
Rob
