Who runs 15+ psi on stock sleeves daily?
New User
Re: Who runs 15+ psi on stock sleeves daily? (D-SPEED)
That guy i heard was also pushing it on weekends pumping 18 psi and running at the track every weekend...So far 3 tuners and honda mechanic(mutual friend) have told me stock sleeves CAN handle up to 28 psi if tuned properly. And as far as 15+ psi daily if any car sleeves or not, and gets ragged on nasty every day something is bound to f-up no matter what the engine has.
Nick
[Modified by boost killz, 1:51 AM 2/19/2002]
Nick
Re: Who runs 15+ psi on stock sleeves daily? (dlplayboy)
It suck, I want to get my block sleeved before I rebuild it, but I can't be without my car for so long, its my only ride.
Re: Who runs 15+ psi on stock sleeves daily? (austrian type-R)
I ran 16-18psi on my engine with stock sleeves for 12,000 miles. I had JE pistons and crower rods though. I ended up blowing a vacuum line to my map sensor at 16psi and running super lean and detinating really bad. I broke two of the JE pistons and put a little mark on one of the cyl walls (because of the piston breaking). But never the less the cyl walls looked clean and perfect. Im surprised they didnt break when i detinated so bad which such a high boost. Honda cyl walls are very strong if tuned correcly.
BTW 16psi was on pump gas, 18psi on race gas. 9:1 JE pistons.
liam
liam
Re: Who runs 15+ psi on stock sleeves daily? (superfastCRX)
I run 14psi with stock sleeves but its only been about 1000 miles so i'm not the best person to give advice on reliabolity.
we've run 20 lbs + with headgasket and race gas. 12lbs w/headgasket and 93 octane. 15lbs w/pistons/rods/93 octane. if you tune it well, it will all work. with a standalone, you can push it even further. we know someone who pushed their stock block to 475 w/haltech. stock honda parts work.
Re: Who runs 15+ psi on stock sleeves daily? (jinxproof99)
I run 16psi on 93 octane on stock sleeves on a LS every day over a year now, people do not understand its all in the tuning. ( key word TUNING)
Re: Who runs 15+ psi on stock sleeves daily? (DRAGLS)
Re: Who runs 15+ psi on stock sleeves daily? (LsTurbo91)
Standalones offer much more precise tuning than you can ever expect to get with a piggyback or FMU setup. Not to preach that my plan is the best or anything, but in general a standalone is safer on the car and will provide more HP than other methods.
Re: Who runs 15+ psi on stock sleeves daily? (97CivicFerio)
I ran 15 PSI on stock sleeves for a while before my piston rings gave up. The stock sleeves looked perfect!
Re: Who runs 15+ psi on stock sleeves daily? (BG Boost)
15+ psi DAILY on pump gas will eventually crack your sleeves. Just a matter of time. If you are rebuilding your bottom end - might as well go and get the block sleeved.
blazin
04-03-2003 09:38 AM
