Who makes a quiet BOV?
Re: Who makes a quiet BOV?
Under 10psi the BOV is really not too audible IMHO. If you want it quieter route the port on the BOV back into the intake piping that connects to the throttle body like boosted stock cars. You will still know it's there, but it won't be like an open atmosphere BOV.
Re: Who makes a quiet BOV? (4sdB20)
You could use the TYPE-S and run a rubber hose off the outlet and route it further away, the rubber hose should help quiet it down, if you want it even more quiet, run one of those mini K&N filters at the end of the hose. Just a thought, I have never tried doing this.
Re: Who makes a quiet BOV? (Chris1091)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris1091 »</TD></TR><TR><TD CLASS="quote">1st gen talon/laser/eclipse's BOV.</TD></TR></TABLE>
agreed if not that at low psi the greddy type s is effective and sounds great!
Re: Who makes a quiet BOV? (bluebullet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluebullet »</TD></TR><TR><TD CLASS="quote">TiAL is fairly quiet....not obnoxious.</TD></TR></TABLE>
And the quality of the TiAL bov is great.
New User
yup i have one of those at 7psi its really quiet. (open to atmosphere). if you get a recirculating bov plumbed back into the intake its really stealth.
yeah u can do it like how MAF metered cars do..recirculate it back into the charge pipes...this makes it stealth
the stock DSM 1st gen would be quiet too
Re: Who makes a quiet BOV? (TurboR1391)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboR1391 »</TD></TR><TR><TD CLASS="quote">Under 10psi the BOV is really not too audible IMHO. If you want it quieter route the port on the BOV back into the intake piping that connects to the throttle body like boosted stock cars. You will still know it's there, but it won't be like an open atmosphere BOV. </TD></TR></TABLE>
Re: Who makes a quiet BOV? (u2civic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alloutmotor »</TD></TR><TR><TD CLASS="quote">yeah u can do it like how MAF metered cars do..recirculate it back into the charge pipes...this makes it stealth
the stock DSM 1st gen would be quiet too</TD></TR></TABLE>
it's a bypass valve, and yes, its completely quiet. *supposedly* there's an advantage to doing it(says porsche), but i dont buy it. if you wanna weld a nipple on your intake you could do it, but i dont think its worth it. the bosch valve is like $40, but the diaphragm will eventually rupture after about 50-60k miles(its plastic). im planning on taking mine off, call me a ricer, but i like the whooooshing sound.
Re: Who makes a quiet BOV? (951)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 951 »</TD></TR><TR><TD CLASS="quote">
it's a bypass valve, and yes, its completely quiet. *supposedly* there's an advantage to doing it(says porsche), but i dont buy it. if you wanna weld a nipple on your intake you could do it, but i dont think its worth it. the bosch valve is like $40, but the diaphragm will eventually rupture after about 50-60k miles(its plastic). im planning on taking mine off, call me a ricer, but i like the whooooshing sound. </TD></TR></TABLE>
Actually the benefit is a lower spool time. It's supposed to knock down the spool up time by reducing the vacuum at the turbo inlet when the ByPass opens. It seem's realistic enugh to me, but I've only had one on a DSM, and I never thought about checking it out untill I swapping it and noticed that it didn't seem as peppy after a shift. Could be my imagination though.
Re: Who makes a quiet BOV? (nd_styles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nd_styles »</TD></TR><TR><TD CLASS="quote">
Actually the benefit is a lower spool time. It's supposed to knock down the spool up time by reducing the vacuum at the turbo inlet when the ByPass opens. It seem's realistic enugh to me, but I've only had one on a DSM, and I never thought about checking it out untill I swapping it and noticed that it didn't seem as peppy after a shift. Could be my imagination though. </TD></TR></TABLE>
It fealt sluggish because it was running pig rich for a seccond. if you vent a MAF car to atmosphere it runs really rich right after a shift because you are letting out metered air. I really doubt you could feel the diff just because of the stronger vac at the turbo inlet thing. maybe though
