who has a turbo b20z
Old 05-11-2003, 04:43 PM
B20 BEAST's Avatar
Default who has a turbo b20z
who has a turbo b20z and how much boost r u running and what times and what trap speeds in what car i have a b20 in a ek hatch full interior and im going to be turbo soon i just have some other things to take care of first then i will be turbo but i would just like to know the times and traps and let me know if u were running street tires or slicks thanks
Old 05-11-2003, 05:06 PM
DaveF's Avatar
Default Re: who has a turbo b20z (B20 BEAST)
every setup will have variations from et's and trap speeds, also "setup", boost and driver dependant.
i think you question is too "broad" for anyone to answer.
Old 05-11-2003, 08:45 PM
TwistedHatch's Avatar
i have a turbo b20z, it's in a 92 si hatch, with power doors and full interior, ran a 12.93@104 today on 24.5 m&h slicks.........no mangement, just stock ls computer and fmu...........i was pretty impressed.........
Old 05-11-2003, 09:50 PM
B20 BEAST's Avatar
ok well how many psi were u on
Old 05-12-2003, 12:41 AM
Default Re: (B20 BEAST)
thats kinda important... i was running on 10lbs
Old 05-12-2003, 02:10 AM
EVOLMTR's Avatar
Default Re: (TwistedHatch)
since we are on this subject.
what's the most hp or boost anyone has made with a stock crv/vtec?
Old 05-12-2003, 11:37 AM
B20 BEAST's Avatar
up
Old 05-12-2003, 11:52 AM
liam821's Avatar
b20z is the weakest honda block. They dont hold up well under boost...unless you sleeve it. I highly recommend you sleeve the block.
They are fast setups tho, my friend ran a 12.6 @ 112 @ 10psi (with BABY slicks) with a b20/vtec setup in a full weight coupe.
but again..sleeve the block or this happens...
This is what it USED to look like..before it blewup..
And now it looks like this...
GE pro-series sleeves
liam
Old 05-12-2003, 11:57 AM
B20 BEAST's Avatar
what about block gaurd
Old 05-12-2003, 12:03 PM
liam821's Avatar
A block guard might have helped...although why use a ziptie when you can fix the problem all together?
liam
Old 05-12-2003, 01:27 PM
B20 BEAST's Avatar
ttt
Old 05-12-2003, 06:53 PM
Default Re: who has a turbo b20z (liam821)
did that motor make any kinda wierd noises when that happened?? did it still run, cause i ran a 12.93 at 104 with my stock b20, no vtec, but before i got to the track, i was playin on the freeway and it started making what seems to be a valve tick, but it runs fine, and upon investigation with a stethescope seems to be bottom end noise??? any ideas?
Old 05-12-2003, 07:57 PM
ion_four's Avatar
Default Re: who has a turbo b20z (TwistedHatch)
was the "tick" at high load? if it is and it was from the bottom end it might be, dum Dum DUM!!! DETONATION! Does your set-up have a knock sensor? I'd rig one up if it doesn't...are you running full ignition advance?
Old 05-12-2003, 08:08 PM
ATYPR's Avatar
Default Re: who has a turbo b20z (ion_four)
We built a car last year with a stock b20z/vtec.
stock block
stock b16 head
old Rev-Hard stage II (t3/t4b)
42lbs mustang injectors (440cc)
v-afc
255 fuel pump
9psi
270hp in a CX hatch
12.2@112mph
Old 05-12-2003, 09:41 PM
no the tick wasn't at high load, the car has been running fine, it just started yesterday on the way to the track, and it's not detonation, no way in hell.......it's like a rod, we've been tryin to diagnose it all day and we have it narrowed down to the number 3 piston/rod.......we think it might actually be a wristpin noise. wich is kinda odd, but i won't know for sure until i actually tear into the motor.....and just fyi i'm running 7 degrees advance, and 10lbs, with a 12to1 fmu and a fpr thats turned quite a ways up......
Old 05-12-2003, 09:44 PM
Default Re: who has a turbo b20z (FUCATYPR)
thats not bad at all, thats what i wanted to do with my motor, but it seems my build up is going to come a little sooner than expected, what tranny was that with?? i only hit 104 but ran a 12.93 on a stock b20z with a ls manifold.....and stock inj. and computer, but i am running a hybrid ls trans with r diff and final drive
Old 05-13-2003, 09:17 AM
B20 BEAST's Avatar
bupm
Old 05-13-2003, 10:54 AM
Brrraaaap!
Blaze45's Avatar
bump
Blaze
Old 05-13-2003, 11:05 AM
B20 BEAST's Avatar
thanks for the bump
Old 05-13-2003, 11:57 AM
Full-Race Henry's Avatar
im buildin a B20 turbo, it will be out soon. I cant wait for it anymore, I need to feel BOOST again.
Old 05-13-2003, 12:22 PM
Brrraaaap!
Blaze45's Avatar
Default Re: who has a turbo b20z (EF8_Fan)
Im a B20 for boost sk2 IM hondasaver cams ghettodyne GE blockguard....
should hual some ***. we shall see.
Blaze
Old 05-13-2003, 12:25 PM
B20 BEAST's Avatar
good luck on the setups let me know what happens
Old 05-14-2003, 10:42 AM
B20 BEAST's Avatar
bump
Old 05-14-2003, 11:28 AM
XDEep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwistedHatch &raquo;</TD></TR><TR><TD CLASS="quote"> no mangement, just stock ls computer and fmu</TD></TR></TABLE>
no tuning either? scarrrry
you can use mustang injectors? what model/years? peak/hold? any different from dsm 450's besides the 10cc's?
Old 05-14-2003, 03:15 PM
B20 BEAST's Avatar
bump
Quick Reply: who has a turbo b20z
