White smoke < After i Boost > Help please !
I have a 97 civic ek and i just recently put on the greddy turbo kit .
I have an FMU , FPR , stock injectors and stock spark plugs .
I Do not have any check engine lights that are on and my coolent level is normal with no over heating !
Smoke will come out of the exhaust when i back up and after i boost . I can drive the car normal and keep it under 3k and i have no smoke . Since it is the Greddy kit with an internal wastegate i was thinking that is what would be dumping the smoke . I am also running a stock exhaust with stock muffler .
If anyone can help me out that would be great . Thank you !
Re: White smoke < After i Boost > Help please ! (a1320addict)
I do have a Blue box , but have not installed it , Should i Do that ? I have a friend that has the same setup but he is not using a Fuel pressure regulator and he has never seen smoke!
And Also i did use the greddy oil return line kit , and it is at an angle because they have a shitty setup for the oil return ! , It is going down but its diagnal not straight down !
Re: White smoke < After i Boost > Help please ! (Si_Element)
how much oil did you put in the car? i have a lil too much oil and my car smokes when it idles for a lil while then goes away. when i gas it no white smoke or when i drive only at idle. thats due to me putting in too much oil .
