Where to get replacement rubber power steering lines for prelude? (to relocate for IC piping)
I was planning on running my IC piping through the hole that the metal powersteering lines run through, but I need to relocate the lines and I've seen people use rubber ones.
Is there a good place to get these? Should somewhere like autozone have them?
It seems like they would have a lot of pressure running through them, so I wanted to see if there was anything special I needed to use. Thanks.
Re: Where to get replacement rubber power steering lines for prelude? (bubs)
Check with industrial hose manufacturing places. I don't know what is around where you live, but here Midwest Hose does anything from hi pressure rubber lines to stainless steel stuff with just about any kind of fitting. If you took your lines in so that they can get the right fittings and knew what lengths you needed to one of those places you'd get what you need.
Just look through your local yellow pages.
Re: Where to get replacement rubber power steering lines for prelude? (Turbo D17)
Thanks I'll have to check around. There aren't many places like that around here, but maybe I'll get lucky.
19dabeast85
01-13-2007 10:10 PM
