where do i put the intake temp sensor on hondata 2000 civic?
Ok as of now my intake temp sensor is right before the turbo and after the filter. but i am told i need to get a obd1 sensor so the hondata reads the temp corectly. but where would and how would i locate it? This is on a 2000 b16a2. thanks
Re: where do i put the intake temp sensor on hondata 2000 civic? (turboex)
Do not put the sensor ahead of the turbo.. The temperature before and after the turbo can vary by more that 100 degrees.. that will cause your car to run way rich.. You need an OBD1 sensor, and tap it into the manifold.. Especially if you are going hondata.. The sensor is very important in open loop..
-Jason
-Jason
Re: where do i put the intake temp sensor on hondata 2000 civic? (TurboCivicSi)
Ok i understand that part. but where do i tap it into? does anyone have any pics?
some people have successfully put the odbII IAT sensor in the charge pipe before the throttle body. no, it doesn't 'blow' out with boost.
Re: where do i put the intake temp sensor on hondata 2000 civic? (brcivic411)
i have mine in the charge pipe before the throttle body. on the 2000 si intake manifold there is a place for it on the manifold on the forth runner. you hae to drill it and use to screws to hold the sensor in place.
Re: where do i put the intake temp sensor on hondata 2000 civic? (redsi37)
any pics of one in the chargepipe? i really dont wanna tak off my mani. thanks
At 10 psi, you can loose as much as three pounds of boost, which later translates into heat, because the turbo must spool harder to overcome the leak.. The name of the game is efficiancy..
You will notice that in a B16 intake, there is an oval shaped flat spot in the top of the runner furthest from the throtle body.. you will need to drill and tap two holes, with a larger hole in the middle for the sensor to pass through.. I am sorry that I do not remember the actual hole sizes, but it is easy to figure out when you get the element.
good luck..
-Jason
[Modified by TurboCivicSi, 7:27 AM 6/27/2002]
