Where is the best place to get bolts for the manifold to attach the turbo up??
I have some but I think they gave up to being all rusty. Where is a good place to get studs or bolts for the manifold to attach the turbo? Please let me know
Re: Where is the best place to get bolts for the manifold to attach the turbo up?? (quikB18B)
how do you know if they will fit..can you just walk in with turbo in hand. im not trying to be a smart ***.
Re: Where is the best place to get bolts for the manifold to attach the turbo up?? (jdm.ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm.ek »</TD></TR><TR><TD CLASS="quote">how do you know if they will fit..can you just walk in with turbo in hand. im not trying to be a smart ***.</TD></TR></TABLE>
same thing I am wondering
yesterday i took my manifold off to weld some of the cracks and while it was off i just brought my turbo and mani to the local hardware store to get the one bolt i was missing (turbo to mani bolt). people look at you weird but what ever i got what i needed. maybe they looked at me cause alittle oil came out of the oil return and i didnt notice lol
Re: Where is the best place to get bolts for the manifold to attach the turbo up?? (civicflnum1)
lol . i guess ill have to take a trip to the store.what do you est you spended on bolts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm.ek »</TD></TR><TR><TD CLASS="quote">lol . i guess ill have to take a trip to the store.what do you est you spended on bolts</TD></TR></TABLE>
just for the 4 bolts that hold the turbo to the mani? 20 cents a bolt and 5 cents a lock washer. BTW ive always had a problem with bolts backing out due to heat changes and vibration. im going to tack weld the bolts in place after i bolt the turbo on (one little piece of weld that i can break off if i ever need to take the turbo off)
thats exactly what I did .. walked into Ace with a Turbo, DP, and manifold...looked around... and got everything i needed for a few bucks...
... why wouldn't you be able to walk in with a turbo??? Its not like they sell them ..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 »</TD></TR><TR><TD CLASS="quote">
just for the 4 bolts that hold the turbo to the mani? 20 cents a bolt and 5 cents a lock washer. BTW ive always had a problem with bolts backing out due to heat changes and vibration. im going to tack weld the bolts in place after i bolt the turbo on (one little piece of weld that i can break off if i ever need to take the turbo off)</TD></TR></TABLE>
cant you just use studs and loctite them in there. So you just slip the turbo on the manifold. Put your washer and then the nut?
Re: Where is the best place to get bolts for the manifold to attach the turbo up?? (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic »</TD></TR><TR><TD CLASS="quote">
cant you just use studs and loctite them in there. So you just slip the turbo on the manifold. Put your washer and then the nut?</TD></TR></TABLE>
loctite will not work. the manifold gets too hot and the loctite will just burn off. lock washers are the way to go
Search under Flamenco-T, he made a thread on bolt sizing, ect... for diffrent manifolds/turbos, If you have a common manifold the sizes should be there.
I used studs on mine, which are more expensive, but they are worth it because exhuast leaks suck
lolz, sorry to be a nOob..
Can someone explain what a stud is? compared to a bolt.... - Thanks..
Re: (Turbo E 604)
I just ordered some studs,nuts, and washers from Flamenco-T. 20 bucks shipped
Should be here tomorrow since we both live in TX
here they are
here they are
Re: (redturbocivic)
sorry to thread jack, but how about manifold -> block? do i need any kind of special bolts/studs or can i just use the ones from the stock header?
Re: (MrCivic98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrCivic98 »</TD></TR><TR><TD CLASS="quote">sorry to thread jack, but how about manifold -> block? do i need any kind of special bolts/studs or can i just use the ones from the stock header?</TD></TR></TABLE>
you can use the one from the stock header
Re: (ha illuminato un)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ha illuminato un »</TD></TR><TR><TD CLASS="quote">here's the link
https://honda-tech.com/zerothread?id=373905</TD></TR></TABLE>
That's exactly what I was looking for. Thanks!
Re: (envision2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg »</TD></TR><TR><TD CLASS="quote">the hard ware store, grade 8</TD></TR></TABLE>
I was using grade 8 bolts from the hardware store (Orchird Supply), and two came out I'm thinking from vibration or they snapped. One I know for sure snapped. I only had one bolt holding my turbo up. I'm going with the stud kit from Fast-Turbo now. I ordered them this morning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B »</TD></TR><TR><TD CLASS="quote">I get all my bolts/nuts/studs at Ace hardware.</TD></TR></TABLE>
Amen to that :-p I go there too . . . . I walk in with my manifold, my turbo whatever the hell I need bolts for that is not to big in size I take it in with me for a sure fit.
Re: (TurboChrgd_Civic)
I might go with a stud also but just wondering if were all having problems with bolts backing out from the vibration and heat how will the studs work better. Not trying to being a jackass i honestly don't understand the concept.
_Endless_
06-09-2003 06:58 AM
