Whats the wastegate set at on this turbo..
I need to know what the factory wastegate is set at for the turbo pictured below.. It is an Airesearch T3 that says a/r .48 on the exhaust housing..
Re: (TheShodan)
I cant find any oe specs for any turbo cars.. I can tell the model number but I cant find the boost settings on the net.. Does anyone have a phone number or website for Airesearch..
Re: (tgreaves)
Update on this.. I opened up the internal wastegate last night and come to find out its adjustable.. I turned down the boost on it to about 6 psi.. When I tested it, it was at about 13 psi.. for Airesearch
Re: (MiraiZ)
And most OEM actuators come staked from the factory so you can't adjust them.
One that you can adjust is the sign of a replacement turbo at some point... standard fair for an OEM turbo car.
Re: (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis »</TD></TR><TR><TD CLASS="quote">And most OEM actuators come staked from the factory so you can't adjust them.
One that you can adjust is the sign of a replacement turbo at some point... standard fair for an OEM turbo car.</TD></TR></TABLE>
I dont really understand what your saying here.. The one that I have doesnt have a rod on the outside of the turbo.. The wastegate valve connects to a diaphram with a bolt holding the diaphram against a spring.. If your turn the diaphram up or down it changes the resistance agains the spring.. Clockwise increases boost and counter lowers it..
Re: (Sulli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sulli »</TD></TR><TR><TD CLASS="quote">I could be wrong but i think Airesearch is Garrett... they might be able to help you out.
Modified by Sulli at 11:39 PM 3/20/2004</TD></TR></TABLE>
They are the same company.. I found out how to adjust the boost pressure in the wastegate..
ITSTOCK
04-14-2004 07:37 PM
