whats the best way to route the boost gauge in 3g gsr
Old 01-26-2002, 04:31 PM
dirtySOHC's's Avatar
Default whats the best way to route the boost gauge in 3g gsr
hi were tryin to put a boost gauge into my friends 01 gsr. we see the hole where we can wire it through(same hole his tach wire goes thru..)but how do we route it thru from there? its gonna sit near a pillar on drivers side...please help
Old 01-26-2002, 04:33 PM
Better than steak
Arturbo's Avatar
Default Re: whats the best way to route the boost gauge in 3g gsr (SO[vtec]HC)
What kind of guage is it?
Old 01-26-2002, 04:34 PM
Default Re: whats the best way to route the boost gauge in 3g gsr (Arturbo)
autometer..were doin it right now...
Old 01-26-2002, 04:41 PM
Better than steak
Arturbo's Avatar
Ok, you need to run the plastic tube from the gauge down to the rubber boot in the fire wall. Once you get it passed the boot then tap the vaccum line.
That is why I chose the Greddy electrical gauge because I'd rather run a wire than a plastic tube. Plus it looks nicer. But thats my honest opinion.
art
Old 01-26-2002, 05:52 PM
Tomakit's Avatar
The greddy mech does look nicer, but the with the autometer there is a more clear distinction between being in boost and being in vaccuum.
The rest of what art said about routing the tube was 100% correct though. Just make sure you dont pinch that small dia plastic tube in any way, or your readings will be incorrect.
Tom
Old 01-26-2002, 06:17 PM
dustin's Avatar
Default Re: whats the best way to route the boost gauge in 3g gsr (Tomakit)
Mechanical gauges are gay.
Old 01-26-2002, 07:17 PM
Better than steak
Arturbo's Avatar
Default Re: whats the best way to route the boost gauge in 3g gsr (dustin)
Yes they are....
art
Old 01-26-2002, 09:24 PM
New User
clean's Avatar
that tubing sucks too. i had it for mine until the boost gauge broke and my new one should be opn its way. i didn't know how to tap a vacumm line w/ that small tube. did anyone change the tubing?
Old 01-27-2002, 12:28 AM
New User
threatcon13's Avatar
Default Re: whats the best way to route the boost gauge in 3g gsr (clean)
when i got the car back from my hondata tuner, the small plastic wire was apparently cut, and the rest of it was covered in a much thicker plastic black hose...so we fed the thick hose down the corner of the dash, came out the bottom, then fed it through the hole in the firewall. then we cut a bigger hole in the grommet w/ a razor, fed it through there into the engine bay. the hardest part was getting that damn grommet back on..took about 20 minutes of tweekin. finally, the boost gauge was on and reading correctly(3 and a half lbs at third gear WOT)...well, tomorrow the other wires get hooked up. thanks for the help guys!
Old 01-27-2002, 09:09 AM
New User
SiR Kid's Avatar
Default Re: whats the best way to route the boost gauge in 3g gsr (turbo01gsr)
I just ditched the hard plastic and put 90 degree barb fitting in the back of my autometer boost gauge... Worked like a champ Ran decent hard Napa Vacuum hose into the cab through a new hole I drilled just left of the brake booster while the engine was out
Old 01-27-2002, 09:16 AM
What is this crap?
falcongsr's Avatar
i ran mine thru the gommet at the bottom of the battery where my fat 0 gauge stereo wire goes. mechanical boost gauges may not be pimpin, but they work fine. How many MAP sensors does your car really need?
*Idea* Why doesn't one of these big companies make a gauge that runs off the ECU's MAP signal? I guess because it would be recalibrated for different sensors...now that would be sweet.
Old 01-27-2002, 09:36 AM
New User
SiR Kid's Avatar
Default Re: whats the best way to route the boost gauge in 3g gsr (falconGSR)
Falcon - EXCELLENT IDEA! The MOST accurate FREE to tap into electronic boost sensor of all... stock map sensors
BUT. GM map sensors won't send the same signal as a Nissan, Toyota, Honda, or Mitsu, will it?
Old 01-27-2002, 09:53 AM
What is this crap?
falcongsr's Avatar
Default Re: whats the best way to route the boost gauge in 3g gsr (SiR Kid)
thanks.. but it wouldn't work for those guys using those check valves, which are more 'gay' than a mechanical gauge, in my humble and biased opinion.
it wouldnt work directly for cars like mitsu with MAF or speed density sensors, either.
Old 01-27-2002, 11:05 AM
New User
SiR Kid's Avatar
Even if they have MAF or speed density, they still have to have a MAP sensor, no?
Old 01-30-2002, 11:26 PM
New User
HaUTSaauce's Avatar
Default Re: whats the best way to route the boost gauge in 3g gsr (dirtySOHC's)
can we see some pics when u are done?
Old 03-01-2010, 07:53 PM
customcivic93's Avatar
okay so im trying to wire up my autometer phantom II boost guage but dont know a good source for power to the guage through fuse box i tried the clock/radio fuse in the engine bay fuse box but guage stays on all the time for some reason any suggestions on a different fuse to tap into??
Any help will be appreciated
Old 03-01-2010, 08:11 PM
cbustuner's Avatar
Tap the power and ground off the dimmer switch if it's a mechanical gauge. That way lights come on and the gauge lights come on,lights go off and the gauge lights go off.
I was 15 years old when this thread was first made
Old 03-02-2010, 04:59 AM
Seraph0's Avatar
Haha yeah I saw all my old buddies replying to this thread and said, "Wait a minute?" Wayyyy old topic lol. Dimmer circuit works good for gauge lights.
Old 03-02-2010, 05:19 AM
lyncoors's Avatar
now this guy searched
Old 03-02-2010, 05:25 AM
yes i did took forever too but got my answer
Schister66
04-14-2006 09:43 AM
djnikko
11-28-2003 12:35 AM
T3T495GSR
08-20-2003 04:23 PM
civcexcoupeblack
08-20-2003 01:51 PM
Quick Reply: whats the best way to route the boost gauge in 3g gsr
