whats the bes gt sereis turbo for a b16a engine!!!
hi guys im looking for a gt sereis turbo for my b16a biuld up. the car willl be use omly for dragracing. wonderin what would be the best turbo that i can use!!!! im thinking of using a gt35r... is this ok??? thanks!!!! pls help me!!!
Re: whats the bes gt sereis turbo for a b16a engine!!! (b18sihatch)
i think the 28r would make more 300-350 hp then 350-400 ... with the 28rs 400 flywheel seems possible when you squeze everything out of it... 400whp is realy hard on a 28rs...
but for the fun and if you don't want a dyno queen it's a very good turbo for the b16
Re: whats the bes gt sereis turbo for a b16a engine!!! (B.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinoyk20 »</TD></TR><TR><TD CLASS="quote">hi guys im looking for a gt sereis turbo for my b16a biuld up. the car willl be use omly for dragracing. im thinking of using a gt35r... is this ok??? thanks!!!! pls help me!!!</TD></TR></TABLE>
The 28rs is a great street turbo, but for drag racing, it's going to be a little weak. Definently look into the 3076r or 35r
Re: (pinoyk20)
I think for a 1.6L the gt3076r Is PERFECT
1.8-2.0 The gt35r is a sweet spot.
In my opinion the 35r might be over kill for your power goals especially on the 1.6l
400 HP Club
Re: (BoostedGreddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedGreddy »</TD></TR><TR><TD CLASS="quote">I think for a 1.6L the gt3076r Is PERFECT
In my opinion the 35r might be over kill for your power goals especially on the 1.6l</TD></TR></TABLE> I agree... unless the motor is built.. But for stock application I love the power that the 3076r made for me..
Re: (BoostedGreddy)
What kind of numbers is a 35r good for? It would be a sleeved B16.
Also, what are his power goals anyway? I didn't see it in the thread..
400 HP Club
Re: (wade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade »</TD></TR><TR><TD CLASS="quote">In.
What power could a gt30, one of the larger gt30 spec'd turbos, do on a 84mm built b16,? </TD></TR></TABLE> well im running the 3076r on a stock b16 making 341hp and 217 tq.. just to give you an idea...
im planin on getting a gt3540r is this good for a b16a engine or b18 ls vtec. how much power can i get from this turbo? at what rpm can i expect to get fullboost?????? thanks!!!
Guest
Posts: n/a
Re: (kameleon23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kameleon23 »</TD></TR><TR><TD CLASS="quote">Im making almost 400whp on the 3076R on pump on my 81mm B16! Love this turbo. </TD></TR></TABLE>
the .63 .82 or 1.06?
full boost at what rpm?
Re: (wade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade »</TD></TR><TR><TD CLASS="quote">i know itll make 350. I wanna know what it can damn near max out at. I got the motor, just curious if its enough for my goal.</TD></TR></TABLE>
You don't want to "max" out a turbocharger. Its not good for it. Its a good way of damaging it.
Re: (jDMJeRk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDMJeRk »</TD></TR><TR><TD CLASS="quote">
You don't want to "max" out a turbocharger. Its not good for it. Its a good way of damaging it.</TD></TR></TABLE>
Sounds like a 30r and some laughing gas might be a nice match to get to and through the 500hp range.
Since the ratings are based off of boost pressures and efficiency, if the motor can make more power without the turbo in place, it shouldn't matter what the HP number is so long as the boost the turbo is making isn't outside of the efficiency window...... right?
Re: (tuned_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuned_vtec »</TD></TR><TR><TD CLASS="quote">
full boost at what rpm?</TD></TR></TABLE>
.63ar....not sure about the rpm, but there isnt much lag at all.
Guest
Posts: n/a
Re: (kameleon23)
.63ar....not sure about the rpm, but there isnt much lag at all. </TD></TR></TABLE>
if a gt3076 .63 isnt that bad i wonder how it would be with the next size...gt35r .63. it would move a lot more air.
Re: (tuned_vtec)
if a gt3076 .63 isnt that bad i wonder how it would be with the next size...gt35r .63. it would move a lot more air.</TD></TR></TABLE>
I thought about that too, but i decided to go with the -13 Cartridge on the 3076R, which is not too far from a 35 from what i have been told. Powerband is awesome too!
