What are you turbo crx guys doing about you ic pipeing
Old 02-27-2006, 08:47 AM
92cxturbo's Avatar
Default What are you turbo crx guys doing about you ic pipeing
We are doing a turbo build on my brothers crx, and we just want to know what you guys are doing for your ic piping from turbo to intercooler. I know the full race backdoor setup would work but already got the intercooler piping and johnny race car 8" intercooler. If you have pic it would be helpfully
Old 02-27-2006, 09:00 AM
red_crx's Avatar
Default Re: What are you turbo crx guys doing about you ic pipeing (92cxturbo)
here is a pic of my old crx...hope it helps
Old 02-27-2006, 09:01 AM
wrenchin'
I Have an STD's Avatar
i went up and over into the hole where the A/C used to be, by the washer bottle (u might have to remove the bottle) and then down and over. you will have a good amount of room with this setup.
heres a pic, this is on my DA, but i did my EF the same way.
Old 02-27-2006, 09:23 AM
Charlie Moua's Avatar
Default Re: What are you turbo crx guys doing about you ic pipeing (red_crx)
wow nice guys... hehe
Old 02-27-2006, 09:42 AM
92cxturbo's Avatar
Default Re: What are you turbo crx guys doing about you ic pipeing (Charlie Moua)
Thanks guys thats helps, that is what i want to do just wanted to make sure it would work
Old 02-27-2006, 09:53 AM
splitime's Avatar
I like this format ALOT more...
edit: Pictures are dead as We-Todd servers... sry... below is a dirty pic of my setup... just link to them... prefer to not just host them as IMG....
https://honda-tech.com/zerothread?id=1339065
we did it similarly on my car using an xspower fmic, was a bit shorter than the one in the link... so we just cut a 180 Al bend in half and put it in place of the inlets... tucks around the stock radiator perfectly.
Please note... it was late and we finished it up and just left it all raw... uncleaned... etc... and front bumper is cutout for old fmic setup.
http://129.105.148.252/pictures/fmic%20(small).jpg
http://129.105.148.252/picture...).jpg
Old 02-27-2006, 11:18 AM
TheShocker's Avatar
Default Re: What are you turbo crx guys doing about you ic pipeing (splitime)
I did mine like this:
From the turbo to the intercooler was just a coupler--it was back-door style. From the intercooler to the throttle body was intercooler pipes joined by a 90 degre coupler.
Old 02-27-2006, 11:19 AM
92cxturbo's Avatar
Is your piping going in the holes on the of the car?
Old 02-27-2006, 11:23 AM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92cxturbo &raquo;</TD></TR><TR><TD CLASS="quote">Is your piping going in the holes on the of the car?</TD></TR></TABLE>
That for me?
The only "hack" to the car is cutting out the sheetmetal right where the horns mount. We moved the horns around the corner. This allowed us to tuck between the framerail and the radiator and drastically shorten the IC piping. All bends are mandrel in my setup also... so one can assume it flows quite well.
Old 02-27-2006, 11:30 AM
92cxturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">
That for me?
The only "hack" to the car is cutting out the sheetmetal right where the horns mount. We moved the horns around the corner. This allowed us to tuck between the framerail and the radiator and drastically shorten the IC piping. All bends are mandrel in my setup also... so one can assume it flows quite well.</TD></TR></TABLE>
Ya but i think my ic is a lot bigger than that i will have to go through the hole where the washer bottle is but thanks for the pics and info
Old 02-27-2006, 11:33 AM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92cxturbo &raquo;</TD></TR><TR><TD CLASS="quote">Ya but i think my ic is a lot bigger than that i will have to go through the hole where the washer bottle is but thanks for the pics and info </TD></TR></TABLE>
No problem, I just know that for people that can pull the method I copied from Tony1... its nice for the piping length. And I think Tony1s was a hair long for it doing it like mine... his has the 180 half pieces integrated into the endtank... but we-todd pics are down unfortuantly. His kit is sooo purty.
Old 02-27-2006, 11:44 AM
92cxturbo's Avatar
When it gets up and running can you post the pics
Old 02-27-2006, 11:49 AM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92cxturbo &raquo;</TD></TR><TR><TD CLASS="quote">When it gets up and running can you post the pics</TD></TR></TABLE>
Just refer to the link I posted in my first response. Its to the thread he posted it in. Once we-todd-racing servers are back up, the pictures will hopefully return.
Old 02-27-2006, 11:51 AM
Boosted Chemist's Avatar
As soon as we todd is working i have some nice pic of my piping
Old 02-27-2006, 06:19 PM
92cxturbo's Avatar
Default Re: What are you turbo crx guys doing about you ic pipeing (Boosted Chemist)
Any one else??
Old 02-27-2006, 06:43 PM
Mag00n's Avatar
why cant u guys do a 90 off the turbo and a 180 around? i have 1st gen crx and i have room to do that. whats blocking you guys from doing that?
Old 02-27-2006, 06:56 PM
high boosted rex's Avatar
Default Re: What are you turbo crx guys doing about you ic pipeing (Macan00n)
my setup runs like the pics above through the hole where the washer bottle was, i'm wondering if anyone has done top mount though? i dont know how it would work if possible
Old 02-27-2006, 09:31 PM
crxrocks's Avatar
I heard some talk at some point of someone cutting a 2.5" diameter hole in the sub frame down on the drivers side to pass the charge pipe through. I don't like hearing cut and frame in the same sentence but wanted to see what you guys had done.
Old 02-28-2006, 05:10 AM
92cxturbo's Avatar
Default Re: (crxrocks)
I have seen that befor anyone got any pics of that?
Old 02-28-2006, 07:40 AM
Doodoo's Avatar
Here is mine. My thinking is, if you are not cutting you are not going fast.
BlueShadow
12-06-2005 10:17 AM
crxzcracer
01-31-2005 01:01 PM
corey's96GSR
05-02-2004 08:25 AM
accordking
08-25-2003 06:22 AM
Quick Reply: What are you turbo crx guys doing about you ic pipeing
