what are you guys running for your Timing?
Re: what are you guys running for your Timing?
are you using crome? and at 10 psi it should be around -6 or so at full boost but a dyno will tell you a little more that that. If you have crome i may have a bin for ya
That does not make sense. Please dont give out this kind of advice. OP, go to a dyno and have your tuner find out what timing is best for you. Do no run a map someone else gives you when it is not tuned for your set up.
Timing numbers vary with setup, and with what you're tuning with. If you don't understand that right now then this thread is going to be a great source of disinformation by which you will be successful accidentally, or much more likely crush some ring lands or rod bearings with detonation.
Have fun!
Have fun!
