What to use to clean the oil ports of the junk yard turbo??
i have a junk yard turbo and the oil feed and oil return ports looks kinda dirty inside. what chemical would be safe to clean the inside oil ports? thanks!
Re: What to use to clean the oil ports of the junk yard turbo?? (accordfreak)
I would grab the phonebook tomorrow morning. Find a Turbo Rebuilding shop in your local town. Take it down for cleaning. It shouldn't cost you much.
Plus they can test it for you.
Re: What to use to clean the oil ports of the junk yard turbo?? (RyanAutry)
i corvered the whole turbo in gunk (took it apart 1st), it got all the grease off. then i ran wd40 thru the oil ports.
Re: What to use to clean the oil ports of the junk yard turbo?? (rewsnaeht)
hm i guess WD-40 is safe for the inside? if so, i'll just use that then. thanks
