what turbos fit a sohc greddy manifold?
Also, can I change the flange? Lets say I want to use a T3 turbo, Can I weld on a greddy manifold? Would an adapter plate hang my turbo lower causing problem like the turbo hitting my frame?
I have a CRX.
I have a CRX.
Re: what turbos fit a sohc greddy manifold? (iNetForce)
u could have an adapter plate made that bolts to the greddy manifold and then the t3 turbo bolts to it, you couldnt weld anything... i dont think it would lower the turbo to your cross member unless your using a really thick chunk of metal.....It would only sit it a few inches lower, guys who use the hf manifold and adapter plates never seem to have problems and the greddy manifold basically sits the same way....
carma42
07-05-2006 08:11 PM
maxoutracer
08-02-2005 05:41 PM
