What Turbo size? Mentors Needed!
New plans , I decided to sleeve the block to 84mm with 9:1 compression,there is no point on building the engine for boost without this procedure. I have in mind a gt35R for my goals,but i still need input on the specs.
I thank everybody for ur input,I love Honda-Tech and who supports it.
Im need input on what size of turbo fits better my lifestyle, its going to be for a B18c 9:1 C.R ,port and polish head,ctr cams, ill be driven this car almost everyday. im looking to push 400 whp. advise is needed. thank u.
Modified by ULTRADX at 3:31 PM 7/3/2005
Modified by ULTRADX at 3:43 PM 7/3/2005
Re: What Turbo size? Mentors Needed! (ULTRADX)
Just about any 50 trim and up T3/T4E will do. You should also go with a .63 hotside and a stage3 turbine wheel.
Paul
Paul
Re: What Turbo size? Mentors Needed! (ScottEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScottEK »</TD></TR><TR><TD CLASS="quote">50 trim on a built GSR trying to make 400hp? Where are you guys getting this stuff?</TD></TR></TABLE>
50-trim's have made 400 WHP on DSM's with poor flowing mitsu exhaust housings, it's attainable.
Re: What Turbo size? Mentors Needed! (Chip)
bump for some more info...looking into this as well, Im trying to make 350whp daily driven with a similar setup (9.1 or 9.5 comp, no sleeving just rods and pistons) I was also looking into something not too expensive and will have decent spool time for a fun daily. Through my research I think ive almost settle for a gt32r or a to4e (50 or 57 trim which ever yields the best spool time w/o loosing its steam up top) , anyone with insight would help (or just to correct me, im a noob to boost)
Modified by Josef83 at 10:21 PM 7/2/2005
Re: What Turbo size? Mentors Needed! (Josef83)
This isn't a stock DSM though, this is a mildly build GSR. I wouldn't even consider running a 60 trim with those goals.
Re: What Turbo size? Mentors Needed! (b18prl)
u can do it with with a t3/t4...there are kits that have those turbos and are efficient enought to make like 450...tuned of course and some wat built with a good engine managment....plus u wont have lag...just my .02
Re: What Turbo size? Mentors Needed! (SPNFEDEJ)
i'd like to know how hard you'd have to push a t3/t4 60 trim to make 450hp, this is what i cannot decide. get a smaller turbo and push it to its max to make the power i want. or run a bigger turbo and not push it as hard.
If you are coming from the NA world, a GT28RS or a GT30R would be great choice. A GT28rs will spool before 4200 and pull hard til readline. I dont recommend a SC61, I had one and if your goal is only 400hp, the lag will kill you.
Re: What Turbo size? Mentors Needed! (red_crx)
thank u for ur advise,i changed my mind on the engine built up. I have in mind a gt35R,but i still need what spec will work better for me.
