what turbo should i get
what turbo should i get for my b16 (SI) if i wants to make like 300 ish ***** on the stock motor tuning with hondata?
Re: what turbo should i get (DubyaAye)
You'll get a lot quicker responses if you tell us more than its just a B16 shooting for 300hp. Is this motor going to be built, if so, to what extent, how high in rpms will you be taking it, are you concerned with low end torque or a long smooth pull, daily driven, etc. Id say a variation of T3super60 would be plenty as its not a huge motor, but this turbo will platue in power around 7000rpms or slightly sooner, great low/mid torque but lacking in the top end in my expereinces(used on a d16 amonst others). There is a hybrid you can have made through Garrett(im sure other companies as well) turbine engineering distributors that runs a certain turbine/compressor wheel combo that is far more agressive than the super60 trim, but i dont know it off the top of my head. If your planning on going higher thatn 280-300whp you're going to need to consider a different turbo, but again, hard to recomend anything without more information.
Good luck
Good luck
Re: what turbo should i get (Distorted)
how high in rpms will you be taking it at most is 8k
are you concerned with low end torque or a long smooth pull don't really matter
daily driven yes
i was thinking of a garrett t3/4e with a .63 ar 57 trim or either a precision sc50 with a .48 63 trim.
daily driven yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DubyaAye »</TD></TR><TR><TD CLASS="quote">how high in rpms will you be taking it at most is 8k
daily driven yes
i was thinking of a garrett t3/4e with a .63 ar 57 trim or either a precision sc50 with a .48 63 trim. </TD></TR></TABLE>
even the t3/t4b would work fine...50trim t3t4e works too
daily driven yes
Re: (this guy 2fast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by this guy 2fast »</TD></TR><TR><TD CLASS="quote">i personally take alot of liking to the presion sc61</TD></TR></TABLE>i like the sc61 too, but most people think its too big for a stock b16.
