what thermostat for turbo?
would i be doing a mistake by getting a OEM thermostat for my turbo GSR , if i need an aftermarket one, which ones are good to be looking at?
Re: what thermostat for turbo? (blakacintegra)
OEM is fine but if you want there is some on ebay that open up about 20 degree sooner than OEM, OEM work great for me so far though so why fix something that is working like it should.
run a stocker...check you logs and see how it holds out....you dont always want the motor to run colder....esp since you in a colder lcimate area...and plan on drivin the car into this late novermber weather....being colder isnt always better....and its been proven that a decent cooling setup should be more than effiecent for an hp level
tekstyle
08-19-2009 12:32 PM
