what are the sizes of youre chargepipes ?
Old 03-04-2005, 01:10 PM
RACEPAK's Avatar
Default what are the sizes of youre chargepipes ?
as topic says
what size are youre charge pipes ? and what turbo ?
best regards moshik galimidi
Old 03-04-2005, 02:13 PM
miro_gt's Avatar
Default Re: what are the sizes of youre chargepipes ? (RACEPAK)
2.5" ... will be, just need to put it on.
It's a GReddy 15G kit .. on my D16Z6...
.. but I think 2.5" is pretty enough for a large range of power ...
Old 03-04-2005, 05:55 PM
platinum00's Avatar
2.5
make your change pipes as close to your Throttle Body size as you can.
Old 03-04-2005, 06:01 PM
YiNYaNg's Avatar
2"-2.5"
14b Turbo
Old 03-04-2005, 07:07 PM
rocket256's Avatar
Default Re: what are the sizes of youre chargepipes ? (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">2.5
Old 03-04-2005, 07:10 PM
96-EJ6 B18C's Avatar
Default Re: what are the sizes of youre chargepipes ? (rocket256)
2.5
Super 60 T3
Old 03-04-2005, 07:17 PM
vr6chris's Avatar
Default Re: what are the sizes of youre chargepipes ? (96-EJ6 B18C)
i ran 2.5" on a t60-1 T4 with ceramic ball bearing and a .96 AR. Had a big greddy front mount. seemed to work well. I sold the whole setup, and now im going with 3" piping. My new setup is GT40 with an air/water setup. Spearco core has 3" inlet and outlets.
Old 03-04-2005, 07:28 PM
adseguy's Avatar
Default Re: what are the sizes of youre chargepipes ? (vr6chris)
2.5" charge pipes
t3/t04e 57 trim .63/.60 turbo
Old 03-04-2005, 10:09 PM
1Bar GSR's Avatar
Default Re: what are the sizes of youre chargepipes ? (adseguy)
2.5" charge pipe
sc61 =D
IT WAS MADE BY PHIL AT SPOOLINPERFORMANCE.COM GREAT PRODUCT!!
Old 03-04-2005, 10:25 PM
DENCIO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">2.5" charge pipes
t3/t04e 57 trim .63/.60 turbo</TD></TR></TABLE>
Old 03-04-2005, 10:27 PM
PrettyLude's Avatar
Old 03-05-2005, 01:15 AM
dornon13's Avatar
Default Re: (PrettyLude)
i concur
Old 03-05-2005, 07:49 AM
blackeg's Avatar
Default Re: (dornon13)
im going to be running 2" from the snail to the i/c, and 2.25 from the i/c to the tb. im only gonna run 8ish psi, so i dont think it should be too much of a problem
Old 03-05-2005, 07:51 AM
DaX
DaX's Avatar
2.5"
T3 Turbine, .48 A/R, Stage 3 wheel
T4 Compressor, 60 Trim, .60 A/R
Nearly ZERO turbo lag...this thing spools like crazy...
Modified by DaX at 12:02 PM 3/5/2005
Old 03-05-2005, 07:53 AM
vtec.dc2's Avatar
Default Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">im going to be running 2" from the snail to the i/c, and 2.25 from the i/c to the tb. im only gonna run 8ish psi, so i dont think it should be too much of a problem</TD></TR></TABLE>
i think thats what i run, either that or 2.25" and then 2.5".. i just remember the diameter increases as it gets closer to TB.. this is with t3 .48 / t04b 50 trim
Old 03-05-2005, 09:26 AM
B6tPoweredMx3's Avatar
Default Re: (vtec.dc2)
2.25 from the snail to the intercooler and then 2.5 from the intercooler to the throttle body.
Old 03-05-2005, 09:59 AM
oxSLEEPERxo's Avatar
Default Re: (B6tPoweredMx3)
2.5
BlackT5
01-11-2007 06:27 PM
hatchinprogress
01-09-2006 11:32 AM
integrx
11-09-2003 08:28 PM
thaiphob
10-01-2003 01:38 PM
civcexcoupeblack
08-10-2003 07:50 AM
Quick Reply: what are the sizes of youre chargepipes ?
