What size injectors for gt28rs on b18c1
Stock B18c1 - XS engineering kit - gt28rs turbo
Only thing left to order is the injectors the optional fuel kit that i didn't buy called rc 504cc injectors. Didn't say if they were saturated or peak/hold. I have talked to two dif tuners and have heard 2 dif options. My local tuner said to use 800cc injectors because i might later use lower compression pistons and up the boost a little more then 7psi. Both tuners said that rc were over priced and that they had similar or just as good injectors for less. I know that with peak/hold there is a resistor you have to mount that can be a pain in the *** but all that aside im still tryin to decide what to order. Anyone care to throw in there 2 cents. Also if u got a link to a good price post that to.
Re: What size injectors for gt28rs on b18c1 (redeyz)
I'd say 500-600cc injectors. You could probably go with dsm 450's since the GT28RS usually is for street response rather than max power. If you want to run over 300hp, I'd step beyond the dsm's. The fact is that the GT28RS doesn't make more than 350hp on Hondas under 13psi.
