What size charge piping should I use with t25 on d16a6!?
Got a d16a6 with Y8 intake manifold and t25 I got a PWR intercooler...friends bending the pipe for me but dont know what size to go with.
Any ideas would be great Im running 5-12 lbs bout to go get tuned so 12 let me know
Re: What size charge piping should I use with t25 on d16a6!? (Deluzional)
yea 2.25 will be sufficient for your needs. If you are planning on running more boost though later on, you could always go with 2.5 now.. up to you.
Re: What size charge piping should I use with t25 on d16a6!? (FMX)
So you guys would say that 1 1/2 -2" would be to small?
cause I have 1 1/2" on their now......
Should work fine, but you might gain power by switching over to 2". I doubt you will gain anything going from 2" to 2.5" with your setup. If I were you and I already had everything setup with 1.5" I'd probably just leave it.
Re: What size charge piping should I use with t25 on d16a6!? (Layziebtnh055)
and how does the t25 work? is the boost adjustable or is it set at a certain psi, im plannin on boosting 6-8 psi
boostedcivichatchbacksi
03-25-2004 10:46 AM
