what sensors/accessories are an absolute must have?
Old 07-31-2012, 03:25 PM
Slosc2's Avatar
Default what sensors/accessories are an absolute must have?
Background:
d16z6
fj rods, vitara pistons, 75.5mm, .0035 in piston to wall clearance.
Acl race bearing, all of em. OEM oil pump. New water pump and timing belt, and tensioner..
Head:
Stock port, decked head and block.
new OEM valves
Comp valve springs, Ti retainers, new OEM valve locks.
Comp 59300 Cam.
ARP head studs
ARP 2000 rod bolts on the I beam rods.
My question: what sensors/accessories are a must have? As of right now, I have:
Distributor
Fuel Injectors
Alternator
Map (3bar)
TPS
I have excluded everything else (right now) as I am unsure if they play a significant role in the correct running of the engine. Tuned on crome.
what is everyones thoughts?
Old 07-31-2012, 08:06 PM
SpeedOFsmell's Avatar
Default Re: what sensors/accessories are an absolute must have?
What I CAN tell you is that the vtec pressure sensor isn't all that essential as long as you've got a gauge and tend to watch what your car is doing. If you bypass that sensor, it makes a great place to mount a turbo oil feed line.
jdmboostedek99
Mid-Atlantic (Sales)
04-29-2015 11:06 PM
jdmboostedek99
01-08-2015 03:19 PM
Slosc2
16
08-04-2012 04:29 AM
d1ck
11
02-03-2012 03:29 AM
ALLOUT CL55
Northern California (Sales)
28
07-11-2011 06:06 PM
Quick Reply: what sensors/accessories are an absolute must have?
