what rpm you guys reach full boost at?
Re: what rpm you guys reach full boost at? (SiBirdie)
i dont really hit full boost until around high 5s. DRAG3. but my friend LS civic hits it much sooner with the same kit.
Re: what rpm you guys reach full boost at? (integRated109)
I don't get full boost till nearly 4K on my GReddy kit Damn stock DP, cat and exahust are choking my turbo!
~3200 for me.
5th gear floored from ~idle for max load. Positive pres. ~ 1200RPM. 2psi by ~1500. 4psi by ~1800. Starts climbing fast at ~2500.
New User
Re: what rpm you guys reach full boost at? (ek9t)
About 3500 here with my shitty exhaust probably could spool slightly faster once I open it up to 3". bTW VTC GET AN EXHAUST!!
Re: what rpm you guys reach full boost at? (b18bturbo)
How about the drag kit on a b16a2? someone told me 6000k .. this with 3 " thermal exhuast thanx
must be smoking crack 6k there no way std drag kit will need to spool that high. It more like 3200
i hit my max of 29psi at around 6300rpm on my T60-2, it is scary when you hear this pinwheel wind up.
Re: what rpm you guys reach full boost at? (Arturbo)
What are you hoping to learn from this post? People with all sorts of different engines and setups are replying. Of course the spool up time is going to be different for everyone of these people. If you're looking for "standard" kits on stock cars, you'll only find a couple on this board.
Smarter than you
making the assumtion that a stock GSR with stock Revhard kit will spool to 7psi at 4000rpm.. How many extra RPM's would it take to spool to around 14psi?
Re: what rpm you guys reach full boost at? (FAST94GSR)
No, its a full street car with some race modifications, - thats how I answer the cops around here. car looks bone stock exterior. its basically an LS integra with built block, My own stage 3 head, ACT clutch, DFI marine unit, RC 850's, mixed up gearing, the new turbo (t60-2) was for an all track car that I scooped and tuned to just about be streetable with the EBC. got bored spent 3 days deburring the head, went thru like 5 carbide tips, think my head weighs 5 pounds less (not recomended), copper head gasket, o -ringed head, lightened flywheel, 7025 aluminum retainers, crower dual prings, manley exhaust valves, stock intake valves, sheet metal intake manifold, Ford 75mm throttle body,halmeter, GReddy EGT, crappy laptop - good program, LSD, home made shafts, no wing no stickers no effects, etc etc.
It does 10's now day or night, hot or cold, rain shine or snow!
cheers
cheers
Re: what rpm you guys reach full boost at? (rtype11)
