What a/r turbo on b20/vtec?
I have a b20/vtec,je 9.5:1 pistons,eagle rods,arp everything,stock itr head with skunk2 cam gears.Im getting 450cc inj,a edelbrock fuel rail and fuel regulator.
what spec turbo would you guys suggest i use?and what size i/c piping.
also what size i/c would fit in a stock ek sir bumper?
Re: What a/r turbo on b20/vtec?
Everyone is going to ask your goals, and what your going to do with the car, but I recently rode in a stock b20 with a 57 trim t04e with a .63 hot and it pulled ok on low boost on the street.
Im looking around 270-300 hp I daily drive the car but I go to the local 1/8th drag track almost every weekend..looking to get in the 7 second class on the 1/8th..
7s sould be very simple.. i went 7.4 with a stock bottem end b16, with a t3/t61 at 12psi.. on drag radials.. if i were you having a built motor sould be able do do this no problem..
You should go bigger on your injectors, maybe like a 750cc/780cc that way you dont have to upgrade later when u get more boost hungry, especially with that built bottom end. I would assume the 450's would have a high duty cylce at around 300whp anyway.
I dont have a manifold or anything as yet,I want to try keep my a/c and p/s if possible.
I ve been looking at the ones on spooledperformance.com..anyone got anything to say about them?
what a/r should i go with?
